P0496 EVAP Purge Valve Replacement
incavulator
Sorry for the long delay here. Was out of town. I think the following explains why some users are being told the purge valve is not a covered component under the federal emissions warranty. I do not think this is technically correct, and I believe this will explain it......
There are two categories under the federal emissions warranty:
1) Those components covered for 8 years or 80,000 miles. Only specific components are included in this category (shown below, underlined in red). Those components include the catalytic converter, electronic emissions control unit (ECM/ECU), and "onboard emissions diagnostic devices, including the Battery Energy Control Module (BECM)." This last category is most confusing and the best I can come up with is this refers to any device or module that makes official emissions-related diagnostic decisions (illuminating the check engine light). In researching what "onboard emissions diagnostic devices" means, it seems it consists of the PCM (already mentioned as ECU/ECM), diagnostic software and memory (which is part of the PCM/ECM/ECU), the MIL lamp, the OBD communication interface, and integrated monitoring functions for catalyst monitor, O2 sensors and heaters, EGR system, evaporative emission control system, fuel system and trim, misfire detection, secondary air system (if equipped), and electronic inputs/outputs to the PCM. The next logical question is, "what are integrated monitoring functions?" What I conclude here is that this describes the software functions that perform the monitoring of the emission components listed. Once again, these are likely just the software features that monitor the emissions systems described above for malfunctions, and as far as I can tell, this would just be one more way of saying the PCM/ECM/ECU or any other module that makes emission-related diagnostic decisions (referred to as DEC ECUs by CARB - Diagnostic or Emission Critical electronic powertrain control units).
2) All other covered components. In this category, the federal emissions warranty is surprisingly only 2 years/24,000 miles. As you can see below (circled in red), the factory Ford bumper to bumper warranty actually exceeds this at 3 years/36,000 miles and Ford even specifically calls this out. What I suspect (?) is happening is people are experiencing these purge valves failures outside the 3 year/36,000 bumper to bumper warranty and therefore, Ford is saying it's not covered. To say it's not covered because it's an "electronic or electrical component" seems completely incorrect. As mentioned previously, there are numerous electronic components listed on the "covered parts" list, so I don't think this explanation is technically correct, even if this is the reason cited by the dealer.
I think what is meant by the dealers when they say it's not covered is that the purge valve is failing outside the federally mandated 2 year/24,000 mile requirement, AND more importantly, outside of Ford's 3 year/36,000 bumper to bumper warranty, OR that it is not covered under the 8/80 federal warranty (which is correct) . Therefore, it's simply not covered because it's outside of the required (and optional) warranty coverage periods, not because it's "not a covered component" or because "it's an electronic/electrical component." Unfortunately, the end result is the same (no coverage!), but understanding the reason for the denial was important (at least it was to me).
If there are users that are experiencing purge valve failures prior to 3 years/36,000 miles and Ford is saying it's not covered (which seems completely contradictory because if that is not covered, what exactly does "bumper to bumper" mean?), I would be interested in hearing that story. The other category of customers that should have better protection are those in CA, as their emission warranty requirements are more strict than federal requirements.
I also think this means that claims that Ford modified the part number to include hoses as part of the purge valve assembly so the component would no longer be covered under warranty are also likely incorrect. I don't see anything in the requirements that would indicate that attached hoses or a change to the base part number would result in a change to the warranty requirements of a covered component.
NOTE: This is based on information from the 2022 Ford Warranty Guide. I realize there are users who have had their purge valves covered under warranty on other brands, models, or other model years. I suspect those may have been replaced within the 2/24 or 3/36 warranty periods, OR those manufacturers/dealers may have been operating under different (better!) interpretations of emission warranty requirements at that time.
Ford Bronco Sport P0496 EVAP Purge Valve Replacement 1756346892189-3q
GGrizzy
daylan
colorado springs
2021 ford bronco sport
I have been encountering a MIL (Check Engine Light) with a P0496 code. I had the dealer replace the EVAP purge valve assembly 2-1/2 years ago. Along with the MIL, after filling the fuel tank it has been very hard to start.
I ordered a new EVAP purge valve assembly and replaced it this weekend. If you have been wondering what all the tubing on the top of the engine is for, it is the EVAP purge valve assembly.
This was an easy 15 minute replacement.
Ford Bronco Sport P0496 EVAP Purge Valve Replacement IMG_4717
Ford Bronco Sport P0496 EVAP Purge Valve Replacement IMG_4719
Ford Bronco Sport P0496 EVAP Purge Valve Replacement IMG_1636
Ford Bronco Sport P0496 EVAP Purge Valve Replacement IMG_4720
did everything pictured come with the part number LX6z-9D289-SJ
thomasm23
thomasm23
Los Angeles Metro
Yes. The part number in the photo includes all the hoses and valve. Everything you need is included in the package. Everything is also assembled. You just remove the existing unit and replace it with the new unit.
Garth
Garth
Ontario
That sounds like bs from Ford, once they replace a mechanical mechanism with electric control they shouldn't be able to squeeze out of it. As I read more about issues with modern vehicles around the world it seems they have a problem everywhere when they electrify systems. And they seem to charge more for a fix as if they are a state secret even though they fail regularly.
Ive only had my BL a few weeks, the previous vehicle was a 2010 crv and its concerning how many critical functions like changing gears etc. are fly by wire. I’ll need to start learning programming just when I finally got my tool kit up to snuff, just saying, There are many more manufacturers of higher end vehicles doing worse.
Stircrazy
BC, Canada
93,000 miles. Out of all warranties for me.
Now I have a cracked catalytic converter (not from physical damage). That waited till it was out of warranty too.
Going to pull it out and weld it up myself as soon as the weather warms up
that should be covered under the 25N03 service campaign still.
Stircrazy
BC, Canada
Unfortunately, that is a Canada only Service Campaign. I was hoping it would extend to US, but no such luck.
oh really, that's a firs,t we get something that you guys don't usually it is the other way around haha. I wonder why that is seeing as it deals with exhaust gasses.
carbajal142
marcos
2022 bronco sport big bend
Is there a link where you purchased it ? I keep getting “does not fit your bronco “
Big Kahuna
William
Oakhurst
theshockleys.com
2021 Bronco Sport Badlands, 2014 Ford F350 Lariat
Big Kahuna
William
Oakhurst
theshockleys.com
Big Kahuna
William
Oakhurst
theshockleys.com
Okay, I just got the part.... dang that's a lot of connectors. I'm going to try to swap it out over the weekend. Does anyone have any tips before I start?
