25-2051 Moan Noise In The Rear Brakes
Fuzzbear
Chris
Richmond, CA
2022 Badlands, '21 Badlands (RIP), '02 Ranger Edge
Anyone have this done and know if it worked?
Oh, for Pete’s sake, I had the previous one done on April 3 and it didn’t work. I wonder if I should go back for this one? What’s different about it from the last one?
Me3
Paul
Northern Nevada
RAV4
I get the moan fairly often when I start backing out of the garage. I immediately lift up on the brake pedal slightly, then resume pressing it as I back out and the noise is gone. It’s gone for the day.except for a couple of times when I was out in the rain doing errands where it started again. It took a couple of momentary lifts before it stopped making noise.
I guess I’m lucky it hasn’t been as bad as many of the reports here, and haven’t felt the need to take her in for treatment.
Escp2BroncoS
2022 Bronco Sport Outer Banks
Is TSB 25-2143 still the most current TSB for the brake moaning problem? Are dealers performing the service under warranty? Anyone have success with this TSB resolving the problem or at least reducing the noise?
Every time my daughter tries to have this service done the dealer says they aren't doing the TSB and are waiting for the next one.
rugedraw
Javier
Miami, FL
Latest is 25-2438 sent to dealers on 9/18 and effective 9/19. See attached.
Fuzzbear
Chris
Richmond, CA
I had the last TSB performed in (I think) April and it was better for one day and then got significantly worse than before it was done. It now moans every single time I back up, regardless of conditions, and I’m pretty sure it’s louder. The service advisor helping me said he would wait until they came out with a definitive fix before trying again. I wonder if this falls under that category, but the description doesn’t seem like anything has really changed, does it?
“This bulletin supersedes 25-2143. Reason for update: update the production fix date”
rugedraw
Javier
Miami, FL
You could very well be right. I didn't check it against the previous version to see if anything changed procedurally.
