25-2051 Moan Noise In The Rear Brakes
EDITED: jump ahead to this link:
https://www.broncosportforum.com/forum/threads/25-2051-moan-noise-in-the-rear-brakes.13913/post-236702
TECHNICAL SERVICE BULLETIN TSB 25-2051
Moan Noise In The Rear Brakes When Vehicle Is Driven In Reverse In Cold Weather And/Or High Humidity
Date: 17 February 2025
Supersedes TSB 25-2031
This is another TSB for the Moan Noise In The Rear Brakes.
I'm unable to locate a good PDF but you can easily find TSB 25-2051 if applicable to your vehicle on Ford's Technical Service Information website (enter your VIN for best results).
https://www.ford.com/support/service-information/
For those interested here is some of the history:
TSB 25-2051
This bulletin supersedes 25-2031. Reason for update: update the parts list.
The following TSBs likely are superseded but confirm with your Dealership.
TSB 25-2031. (superseded)
TSB 24-2348
This bulletin supersedes 24-2326. Reason for update: update the causal part number.
https://www.broncosportforum.com/forum/threads/24-2348-moan-noise-in-the-rear-brakes.12472/post-206807
TSB 24-2326 (superceded)
TSB 23-2308
Moan Noise In The Rear Brakes When Vehicle Is Driven In Reverse (R) In Cold Weather And/Or High Humidity, Supersedes 23-2041
https://static.nhtsa.gov/odi/tsbs/2023/MC-10244711-0001.pdf
TSB 23-2041
Moan Noise In The Rear Brakes When Vehicle Is Driven In Reverse (R) On Cold Weather And/Or High Humidity, Supersedes 22-2326
TSB 22-2326
Brakes: Updated caliper mounting hardware Brake reverse noise: Replace rear caliper bushings using a thicker slides pin bushing.
DG9Z-2C150-B: BOLT, Qty: 2
CV6Z-2C150-A Kit ??
remove and replace rear bushings in rear brake calibers per TSB 22-2326
1. Go to NHTSA.gov.
2. Click "Recalls."
3. Click the "EQUIPMENT" tab.
4. Click "search by NHTSA ID."
5. Type "10218630" in the search box and click "GO."
https://www.broncosportforum.com/tsb-22-2326-moan-noise-in-the-rear-brakes-when-driven-in-reverse-in-cold-weather-or-high-humidity/
Me3
Paul
Northern Nevada
RAV4
Geez. Bunch of genius engineers. Did they finally figure it out?
Uncle Brad
Brad
Indiana
2024 Bronco Sport
My wife has a 2023 Escape, which falls under the TSB. Her rear brakes were howling like an enraged Sasquatch. She took it in to the dealer this week under warranty , and they had a great attitude. Will see how well the fix works when it gets colder.
DonImbimbo
Don
Wellsboro, PA
We have had this noise on our 21 ever since new. I just ignore it because it does not happen consistently.
paula fong
P
Granada Hills
Thanks, Dude!
Fuzzbear
Chris
Richmond, CA
2022 Badlands, '21 Badlands (RIP), '02 Ranger Edge
Mine has gotten worse and happens more frequently. I had an appointment for the TSB last June and it got canceled because Ford put a stop order on it in anticipation of a fall update. My BS is now out of warranty, so I guess I get to fight with them that this should still be covered since I made it known and tried to have it addressed during the warranty period. Sigh.
paula fong
P
Granada Hills
I did that, but they wouldn’t give in. They want me to pay out-of-pocket and there’s no guarantee that it is going to work. I sent in a complaint to the FTC. I hope others did the same.
Kagoo143
Charlie
New York
For what it's worth, I had the latest TSB done for this on my last routine maintenance visit (Jan 9th) and have not had brake moan since then.
Fuzzbear
Chris
Richmond, CA
I finally had it done on April 3 — the moan had gotten ridiculously awful. Sadly, it doesn’t seem to have made a difference; after a couple of days, the wailing cow was back at nearly the same level. At least the service advisor made sure I didn’t have to pay for it. I’m debating whether to even tell them it didn’t work at all. At this point I think I just have to wait for the brakes to wear out and try replacing them with ceramic to see if that does it.
TSB 25-2051 (Subject of this thread), now TSB 25-2143 (dated 10 April 2025) which supersedes TSB 25-2095
How could there be so many TSBs all for the same issue?
Ford Bronco Sport 25-2051 Moan Noise In The Rear Brakes Imag
ThatBroncoGuy83
Matthew
Kennesaw, GA
I had the same issue. Sounded like a whale and got worse every day. Finally installed the brass caliper bushings from Damond that were recommended on here and havent heard anything since. Its been about a week now and before I coulnt go more than a day without the whale moan.
paula fong
P
Granada Hills
Anyone have this done and know if it worked?
