EcoFlow Alternator/Charger
TheX
Randy
Austin TX
www.netwerkin.com
What is it? The webpage describes use and installation, but there's nothing about purpose. Is it just to connect a portable power battery to your car? If so, how is it different from just plugging your portable battery into the power outlet in the back?
2025 Badlands Sasquatch
It's primarily designed for RV's, so you have your portable power station either charging directly from the vehicle's alternator (better charging rate than solar or 12V accessory charging), or alternatively reversing that and charging either the chassis or house batteries from the power station. Good idea, but likely overkill for weekending in a BS.
TheX
TheX
Randy
Austin TX
www.netwerkin.com
It has a dual purpose, it also allows me to use big 12vdc batteries easily and most important, efficiently. I will be powering my shed with the EcoFlow Delta Pro and a bank of these batteries.
The shed roof is sunlight all day so it is being filled with rigid panels. It also sets me up to go off-grid if I ever decide to do so.
Ford Bronco Sport EcoFlow Alternator/Charger 1759033451468-69
The one thing to be wary of for ‘21-‘24 Bronco Sports is the videos statement “if your vehicles charging system is not robust..”
I don’t know about 2025 Bronco Sports but I would be wary of the charging system design in at least the ‘21-‘24 Bronco Sports - we know very little about the design of the charging system however we have learned some about how it does operate from various TSBs which updated BMS/PCM software correcting certain shortcomings about the way the alternator charges the vehicles battery.
I probably would also not use the vehicles auto stop/start whenever the EcoFlow Alternator/Charger is in use.
The EcoFlow Alternator/Charger does look like a great device for the features it provides - I would thoroughly test it out under various operating environments with the Bronco Sport within the free return window (whatever that is to return the EcoFlow Alternator/Charger).
The Shark
Cary, North Carolina
I can tell you the EcoFlow Alternator works great on my Bronco with the 2.7 engine, I use it in conjunction with a EcoFlow battery to power my Dometic fridge. But Dude brings up a good point about not knowing the charging system on the BS. You can dial down the amount of watt's it puts out which would put less strain on your charging system.
payhurt
23 Bronco Sport
I have it installed in my 2023 Big Bend to charge a Delta 3 plus for car camping. (Definitely not a "robust" alternator). I've tested it up to the full 800w rated output, and there were no immediate adverse effects. (Even at night with highbeams, fog lamps, ac on, rolling windows up down etc) Having said that - a little research will show that heat kills alternators - therefore, I always adjust the power out to match the scenario. For example - If I'm driving for 2 hours, and the battery needs X input power for x amount of time, i adjust the power to meet that. (I don't just leave it full power). Ecoflow has also enabled car play - so I can keep tabs on everything via the center screen. Pretty cool.
payhurt
23 Bronco Sport
Love this idea!
