- Thread starter
- #16
Wheel well pinch weld fabrication. Someone below showed how they did it . 31 inch tiresThanks. What modifications would be needed to prevent the rubbing?
Are 2 inches larger Than factory Spec. Lifting DOES
NOT help tire clearance, it helps body
Be higher, but IN NO WAY helps
The tires be farther from the body insides
When you rotate the steering wheel. If you had a 1 FOOT lift then you would be ok, but rig would be undriveable ( cv Axle angles woidon’t take the change, balance in turns over 5 mph (way too heavy up high). .
