235/75r17’s fit, barely.
fsjdw2
Jerrod
Maine
2012 5.0 GT convertible, 2022BS BL(pending)
Thanks. What modifications would be needed to prevent the rubbing?
Wheel well pinch weld fabrication. Someone below showed how they did it . 31 inch tires
Are 2 inches larger Than factory Spec. Lifting DOES
NOT help tire clearance, it helps body
Be higher, but IN NO WAY helps
The tires be farther from the body insides
When you rotate the steering wheel. If you had a 1 FOOT lift then you would be ok, but rig would be undriveable ( cv Axle angles woidon’t take the change, balance in turns over 5 mph (way too heavy up high). .
Yes, this has been covered here many times. A lift does not change tire clearance for the BS, at least not a lift that is currently available.
