HVAC Problems
And the external (outside) ambient air temperature sensor also plays a role in the HVAC System
this could also be the cause of your issues
This is located at the front of the vehicle
Ford Bronco Sport HVAC Problems IMG_6853
kthorg23
Karisma
Washington
21 bronco sport
Interesting the diagram makes it look like on the dash
kthorg23
Karisma
Washington
21 bronco sport
My vin does pull up a ton of codes none of which seem to give and answer on what exactly is going on other than modules not communicating properly
Yeah, what @Dude said ^. The interior sensor is easy to get by the mirror. The external one is the one that knows when it's a 75 degree day. The buried temp sensor is to measure the A/C air and adjust the compressor system.
kthorg23
Karisma
Washington
21 bronco sport
Would that really be something to cause the hvac to just shut its self off?
I ordered the b number
It would not be the first time the same part needed to be replaced again
it seems likely it’s the b part (again) … because what else would cause the HVAC display to go blank
well the fuse, the wiring, the connector …
Rodents chewing on wiring …
the inside and outside ambient temperature sensors .. I do not know if one of these failed (at 75°F) if that would cause the HVAC temp control to go blank
And since you have the dual controls, do both go blank? I think your video just showed the driver side control
kthorg23
Karisma
Washington
21 bronco sport
I can verify its not rodents and sounds like not an issue I will be able to get fixed.
kthorg23
Karisma
Washington
21 bronco sport
I updated my prior post to add a question, not sure if you saw that
Its the whole entire thing like I have no power to it what so ever so no air comes out its basically as if you've hit the power button on it
Got it, both driver side and passenger side digital temperature dials go blank at around 75°F and the HVAC is inoperable
is it the outside temp at around 75°F when this occurs or the temp inside the vehicle?
my next post will include things to check … some you can do yourself
kthorg23
Karisma
Washington
21 bronco sport
Outside temp not sure what the inside temp.is since when its doing the issue it doesn't give a temp. And its 75 or above so basically when its hot outside
Does the whole panel not have any power, including the ambient backlighting at night? The lighting comes from another source. The control function is tied one module, the lights to BCM.
