Hood Deflector = Hood Bounce / Flapping
Humper
Mick
Oklahoma
I installed the AVS ll textured hood deflector and man, the hood shake near the top edge (Winshield Edge) is crazy, I was scared to drive more than 60mph.
I have read threads about adjusting the bump stops, will do that and re-test and also inserting 1/4” fuel hose around the hood and the back “bulb”, for anyone that has done this, could you confirm this is the correct hose I need?
1/4 Inch (6mm) ID Fuel Line Hose 15FT NBR Rubber Push Lock Hose High Pressure 300PSI for Automotive Fuel Systems Engines https://a.co/d/iP9oVVQ
1/4 Inch ID 15 Feet Fuel Line Hose for Snow Blowers Lawn Mowers Tillers Motorcycles Mini Bikes Snowmobiles with 6 Fuel Filter 20 Stable Heavy Duty Clamps https://a.co/d/5I55KWI
A 1/4" Inside Diameter, 0.490" Outside Diameter will work for easier fit
This pic shows a 2nd choice (5/16” ID, 9/16” OD) and some links that might still be good
Ford Bronco Sport Hood Deflector = Hood Bounce / Flapping IMG_4264
bdewey
Washington State
Moving from Mazda CX-5 to Bronco Sport in a week
Once Ford gets my windshield in, I am going to have one installed by the dealership, then if I have "bouncing issues" they will have to fix it.
Chiefthepup
Colt
Washington
Got mine to calm down a bit by backing out the bump stops completely(to ensure they were even when reinserting) than doing a full turn in until it stopped. I think the logic is when the latch grabs, the bump stops provide enough pressure against the hood to truly make the latch hold tight. ? Someone correct me if I’m wrong though.
Humper
Mick
Oklahoma
I just installed the same deflector on my hood and have driven up to 80mph without any significant wobble. I must be lucky!
Ford Bronco Sport Hood Deflector = Hood Bounce / Flapping IMG_6675
You must be very lucky, I honest thought my hood was gonna fly off it was that bad.
bozer
brett
manteca ca
2021 Ford F250, 2022 Bronco Sport Badlands
I had hood vibration before AVS deflector and I still have hood vibration after the install, it made no difference. I'll have to try and run a fuel line through the rear hood seal and see what happens.
I ordered 1/4"x5' fuel line for $6.99 off Amazon. I sprayed the fuel line with silicone spray and stuffed it into the rear hood seal and cut off the excess. I took it for a ride on the freeway at 75 mph, no vibration! That was a great tip!! Thank you, I hated that vibration.
bozer
brett
manteca ca
Great tip!!! I used the 1/4" and it worked excellent.
tommy
tom
I put the exact same deflector on my 2021 BS and it didn't help.
bdigna
Bruce
Detroit, MI
Same, vibration before and after without TOO much noticeable difference. and I have had mine on for almost 3 years. I think I'll try the fuel line too, as I've just been living with it.
tommy
tom
I had a piece of 5/16" fuel line, couldn't get it to go into the rear hood seal without possibly damaging the seal, I bought 5' of 1/4" ID x 1/2" OD fuel line at the auto parts store and still had to put liquid soap on it, haven't had a chance to jump on the interstate yet, I'll let everyone know after I do.
