Bronco Sport Lettering
MAJB Retired
Ernie
Greenfield, IN
2018 F150, 2021 Explorer King Ranch, 2024 Bronco Sport BB
I've had the BSBB about a month and just noticed this. I'm thinking the vehicle might have been damaged in shipping and was repaired by the dealer. I haven't seen a BS with the lettering off before.
Ford Bronco Sport Bronco Sport Lettering Bronco Lettering
Those letters are held on by some incredibly aggressive adhesive on some foam tape. Is there any visible damage to the letter that you can tell? I doubt that even the most disinterested employee at the dealership could place the letter that poorly. If you can easily pull it off, or start to pull it off, then it may have either had some contamination on the paint when it was applied in the factory or the same at the dealership (if it was damaged in some way and they replaced it).
MAJB Retired
MAJB Retired
Ernie
Greenfield, IN
That was my thoughts also. I'll probable talk to the dealer and see about get it fixed. Once I saw it I couldn't unsee it every time I look at the BS.
V8 Yankee
Harold
Miami
21 Bronco Sport
Easy fix, take some dental floss and work it behind the letter in a sawing motion. Once removed clean the area and reattach with new trim adhesive. You can find it in almost any auto parts store. Takes 10 minutes or so if you have everything ready when you start. You can try and salvage the existing adhesive and reposition but it won't be as strong and might fall off.
Mwittke5857
Elma, NY
2021 Bronco
IMHO they just look cheesy,I removed them and opted for these
Ford Bronco Sport Bronco Sport Lettering IMG_2273
Hello! Send us a private message with your VIN and current mileage. Allow me to see what I can do to assist. Thanks!
Mwittke5857
Elma, NY
2021 Bronco
I removed the sport letters from my rig. I used a heat gun (you can use a hairdryer if you’re skittish) and a flat nylon trim tool. 91% alcohol works well for removing any remaining gunk. Don’t forget to wash and wax if you’re leaving them off as I did..
Mwittke5857
Elma, NY
2021 Bronco
I ditched the "Sport" off my hatch and went with the F150 Sport decal. Something I thought Ford would have done from the get-go since they had them already
Ford Bronco Sport Bronco Sport Lettering Pass_12-23-24
RM951
Ray
CA
21 bronco sport badlands
I like that @Mwittke5857 . I want to ditch the sport too
wireman
Murrieta
Mike is the pin stripe old school, or a decal? Looks good on the black.
Colonel Angus
Dean
New York
"Ditching" the Sport lettering leaves "Bronco" off center on the hatch. Looks amateurish IMO.
