CarPlay music stops minutes after playing
BeachBuggy
Scott
San Diego
Bronco Sport 2024
About 4 minutes into driving the music cuts out. The CarPlay maps still works. Changed 5 different cables and the problem remains. Anybody experience this issue? Thanks for your help.
Which music input or app?
BeachBuggy
BeachBuggy
Scott
San Diego
Bronco Sport 2024
Youtube Music, didn't have a problem with my other car. What do you suggest? Thanks
thomasm23
Los Angeles Metro
What Build of SYNC 3.4 do you currently have installed?
What iPhone do you use and what is your currently installed version of iOS on the phone?
BeachBuggy
BeachBuggy
Scott
San Diego
Bronco Sport 2024
Just checked.
SYNC 3.4 and iPhone has been kept updated and is updated automatically.
What are your thoughts?
Just checked.
You will need to check which Sync 3.4 version, here are the instructions:
To find your Sync 3.4 Build Version (do not scan for updates):
Select SETTINGS tab, then
Select GENERAL tab, then
Select ABOUT SYNC tab
It will show the Build Version
If needed because is not the latest, the step is to manually update to the latest Sync software
Follow Fords instructions at this link to download to your own USB Device then install Sync in your vehicle.
https://www.ford.com/support/sync-maps-updates/
A direct link to the PDF instructions is here: https://www.broncosportforum.com/forum/threads/sync-map-download.12742/post-211555
iPhone specific section:
Make sure your iPhone is on the latest IOS, you said it updates automatically but please confirm is IOS 18.3.1 or latest.
You can try deleting your iPhone off of Sync using Settings on the 8” Display, remove the vehicle from the iPhones Settings (Settings -> CarPlay), then add your iPhone back to Sync and re-set up CarPlay.
thomasm23
Los Angeles Metro
Just checked.
My thoughts?
Bogus answer.
I asked those questions to assist you. Please respond to my questions.
Thank you.
Have you tried a different app to see if that makes a difference? I use use the XM app on my full size since I don’t have the service for that and it can be glitchy in spots but normally due to the strength of the cell service.
For me, I can’t say that the sync version or IOS version has ever made a difference in the past few years. YMMV.
BeachBuggy
BeachBuggy
Scott
San Diego
Bronco Sport 2024
Thanks for the answer you supplied. Appreciate your help. Thank you!
BeachBuggy
BeachBuggy
Scott
San Diego
Bronco Sport 2024
My thoughts?
Bogus answer.
Thank you.
Sorry, I did not know what you were asking. I'm a new owner and did not understand.
BeachBuggy
BeachBuggy
Scott
San Diego
Bronco Sport 2024
My thoughts?
Bogus answer.
Thank you.
Any update yet?
My build is 23188_PRODUCT. I followed Escape2Bronco steps and downloaded the PDF. The website said that I had the latest updates. Went for a long drive after and it did not happen. The CarPlay did not cut out on the music. I will update after a few more drives if the issue comes back. Thanks for reaching out and helping!
Using Ford’s website is often unreliable for knowing if the vehicle is actually up to date
the only instructions to guarantee you are seeing the installed Sync 3.4 version is the following and these instructions also include checking the iPhone iOS veraion (as in Post #6):
BeachBuggy
BeachBuggy
Scott
San Diego
Bronco Sport 2024
BeachBuggy
BeachBuggy
Scott
San Diego
Bronco Sport 2024
Followed your instructions and think I am updated. Thanks for checking in.
Ford Bronco Sport CarPlay music stops minutes after playing IMG_8507
Ford Bronco Sport CarPlay music stops minutes after playing Screenshot 2025-03-03 at 11.16.20 AM
