- First Name
- Steve
- Joined
- Aug 25, 2024
- Threads
- 12
- Messages
- 485
- Reaction score
- 628
- Location
- BC, Canada
- Vehicle(s)
- 2023 Bronco sport
- Thread starter
- #16
we all know that from reading on here, to make it easier you pull the drivers front wheel liner and you can see the level plug better. what I was surprised about is that they did it with the service plan when the manufactures recommendation is 150000 miles. usually the service plans are based off that.You MUST change the fluid every 30k miles minimum. There is no changeable fluid filter on this transmission, its internal. The process to change the fluid is fairly easy, remove the under-engine cover, and remove engine air filter box. Locate the drain plug under the transmission, remove the drain plug and drain fluid in container. Replace plug. Measure amount of fluid drained. Pull the vent cap on top of the transmission and refill with new fluid of same amount as was drained. Button up engine and transmission items removed.
That’s it; basically a drain and refill.
