Not surprising. I’ve also seen Ford documentation stating Sync 3.4 updates can be done over WiFi but NAV Maps updates must be done over USB.… When I mentioned to the Nav team rep that the owners manual still mentions updates through wifi that just went over her head and basically just kept repeating I am not supposed to be able to update over wifi.
Most likely this is a strong recommendation because Ford knows NAV files are very large and updating NAV over WiFi is a bad idea because it’s an unreliable way to update.
I’ve had the setting disabled for the automatic updates over WiFi since 2023 due to all the corrupted downloads owners reported using WiFi for downloading updates.
I no longer use the scan for updates setting in the vehicle. This has known issues and doesn’t always work.
What does always work for Sync updates and for NAV Maps updates is the USB Device method. Ford’s instructions for this are very clear and easy to follow. The file written to the USB Device after Sync updates complete has to be uploaded to the Ford website and that hasn’t always worked but doesn’t cause any issues.
To be safe, use the Setting on the 8” Display to disable automatic updates over WiFi* and don’t use the Setting to scan for updates.
https://www.ford.com/support/sync-maps-updates/
*Note: Disabling automatic updates could mean not getting updates for other modules - I’ve talked to Ford Techs, some say only Sync is updated over WiFi.
At least one Tech said WiFi is also used to update non-Sync and non-NAV Modules for the Sync 3.4 system.
