- Thread starter
- #1
Has anyone upgraded their steering wheel on Base or Big Bend models from the cra-pay plastic to the leather wrapped Badlands model. It's an easy swap once you figure out where the clips to release the airbag are.
Not a bad option, not quite the look I'm going for, but best of luck with it!I have a Badlands leather steering wheel, but what I really want is this upgrade from Vivid Racing:
https://www.vividracing.com/ford-bronco-sport-oem-upgraded-customized-steering-wheel-p-153697889.html
I’ll have to save my pennies but it looks like it’s worth it.
If you look closely you’ll see that you can customize every aspect of the Vivid Racing wheel upgrade. Materials, color, shape of the wheel, size, and more. The cost varies slightly depending on how much work and materials are involved. However $800 is about the minimum, and you have to shell out $1300 until you send them the core part of your old steering wheel (ouch!).Not a bad option, not quite the look I'm going for, but best of luck with it!
https://www.tascaparts.com/v-2021-ford-bronco-sport--first-edition--2-0l-l4-gas/steering--steering-wheelI am trying to find the right steering wheel for our Badlands.
I think it is this one:
M1PZ-3600-EA
However, I believe you can't buy a leather steering wheel without adaptive cruise control buttons, but we don't have adaptive.
Does this make any difference? Can I change out the button trim?
Hey Colonel Angus, Can you explain how to remove the airbag? I can't see any access holes to push in the clip, nor bolts that hold it in. I have a 2023 Bronco Sport. Thanks!!Has anyone upgraded their steering wheel on Base or Big Bend models from the cra-pay plastic to the leather wrapped Badlands model. It's an easy swap once you figure out where the clips to release the airbag are.
The Colonel seems to be gone. He was a frequent poster but his last time here was Dec '23.Hey Colonel Angus, Can you explain how to remove the airbag? I can't see any access holes to push in the clip, nor bolts that hold it in. I have a 2023 Bronco Sport. Thanks!!
I see this is an old post, did you take the plunge?Has anyone upgraded their steering wheel on Base or Big Bend models from the cra-pay plastic to the leather wrapped Badlands model. It's an easy swap once you figure out where the clips to release the airbag are.
