I have a favor to ask from members with '23-'24 badlands models?
@johnardsg see the blow up pic of your doors, in the ovals are what i earlier referred to as “metal strips” but also see the arrow — at that spot is paint worn off this door?
I see similar “metal strips” on my door pic but just looked abit more pronounced in your pic probably due to lighting and paint color differences.
Ford Bronco Sport I have a favor to ask from members with '23-'24 badlands models? IMG_3631
Hot pepper red
Hot pepper red
Lee
Build date Dec 09, 2023.
Open channel below the wider part shown there. no rubber weatherstrip in the channel.
Ford Bronco Sport I have a favor to ask from members with '23-'24 badlands models? open channel below driver's door
Thank you for responding, I greatly appreciate it.
Hot pepper red
Hot pepper red
Lee
I have a 24 BS Badlands. The rubber piece is not on the trim. It looks like Ford did not redesign the trim piece. They just removed the rubber strip that you are showing in the picture.
Wow, is that weather strip not contributing to the "double seal" of the doors and the vehicles' advertised water fording capabilities!?
Hot pepper red
Hot pepper red
Lee
Hot pepper red
Hot pepper red
Lee
This might have been installed to keep the inside of the door cleaner and reduce some road noise.
Hot pepper red
Hot pepper red
Lee
Thank you to everyone who replied! Hopefully, those of you who are experiencing paint wear issues are able to get it resolved with Ford quickly.
DWG
New Jersey
I just checked the driver door for weather stripping. There is still weather stripping around the bottom of the door where the plastic door panel ends and weather stripping along the perimeter of the door opening on the body of the BS so those two strips look they would touch together when the door is closed. Similar to my other Fords. it seems the weather stripping running at the bottom of the lower trim was causing an issue with the paint so Ford removed it. I am guessing Ford is not going to change the design of the trim piece unless they find water getting into the cabin which I think is probably unlikely. I really looks like the rubber strip was really a poor design if it is causing paint to be worn off from the door rubbing with the weather strip. It would not be the first time that the someone came up with a design idea that turned out to be a bad idea in the real world.
Nickadeamus
Nick
Pa.
2024 Ford Bronco Sport
This is what my 2024 looks like
Ford Bronco Sport I have a favor to ask from members with '23-'24 badlands models? 20240502_185036
Ford Bronco Sport I have a favor to ask from members with '23-'24 badlands models? 20240502_185043
davidg4781
I never noticed this on my Big Bend. I did notice our door doesn't have any additional weatherstripping at the bottom while a CR-V I rode in the other day did. This make some wonder if that is contributing to bugs and dirt I find inside my BS.
Hot pepper red
Hot pepper red
Lee
My 23 Big Bend has it.
Thanks for replying, it appears that this issue is apparent on multiple trims. I assumed the trim was different on the other models.
