I have a favor to ask from members with '23-'24 badlands models?
Hot pepper red
Lee
Hi, I have been having an issue with the paint wearing off on the lower corners of my badlands doors, and Ford is going to take care of the problem because it is covered under warranty.
The favor I am asking is for you to look at your vehicles and tell me if you have the rubber weatherstrip installed on your rocker panel trim.
The service manager at my local dealer is telling me that the new badlands models does not come with this rubber trim installed, and I want to verify this is the case on your badlands. See attached picture.
If the rubber is not installed, did Ford redesign this rocker panel trim or just remove it to prevent the paint from wearing through? Or is this how the service manager thinks he can take care of this problem without fully addressing the issue. Hopefully, he is being honest with me.
Ford Bronco Sport I have a favor to ask from members with '23-'24 badlands models? PXL_20240502_002720667.MP
DWG
New Jersey
I have a 24 BS Badlands. The rubber piece is not on the trim. It looks like Ford did not redesign the trim piece. They just removed the rubber strip that you are showing in the picture.
Hot pepper red
Hot pepper red
Lee
Thank you, I greatly appreciate your response!
DWG
New Jersey
Your welcome :)
RushMan
Russ
NW NJ
'24 Shadow Black Badlands
Build date Dec 09, 2023.
Open channel below the wider part shown there. no rubber weatherstrip in the channel.
Ford Bronco Sport I have a favor to ask from members with '23-'24 badlands models? open channel below driver's door
Hot pepper red
Hot pepper red
Lee
RushMan
Russ
NW NJ
Rogerthat898
Roger
Looking to see if this molding was removed in all 23-24 models.
My 21 Big Bend has the molding along with the paint rubbing.
‘22 Badlands.. I have the 1” rubber strip in the plastic rocker panel. On the bottom of drivers door is a small section (about 1” long and less than 1/8” wide) where paint rubbed off (where arrow points). Rear door on drivers side is fine, no paint rubbed off. I’ll check the passenger side doors later.
See pic:
~3” plastic rocker
1” rubber strip
open channel
Bottom of plastic rocker
Ford Bronco Sport I have a favor to ask from members with '23-'24 badlands models? IMG_3629
Jill
Gillian
Oakville, Ontario
My 2021 BL looks different.
Ford Bronco Sport I have a favor to ask from members with '23-'24 badlands models? IMG_7004
johnardsg
johnard
Texas (previously from PNW)
2021 BS BigBend/2011 v6 Rav4
See pic:
~3” plastic rocker
1” rubber strip
open channel
My 2021 BB is very similar to yours, just extra plastic covers on the bottom holes on all doors.
Ford Bronco Sport I have a favor to ask from members with '23-'24 badlands models? IMG_9031
RushMan
Russ
NW NJ
At the bottom of your door it looks in your pic there is a long strip or build up of metal (running horizontally just above bottom of door, and another running vertically), seems that would add just enough push to prevent the paint from wearing off like OP showed and shown in my pic.
And in addition you got the extra plastic covers on the bottom holes on the doors!
