Cheito
installed new 235/70/17 AT tires on my BB. Gives it a meaner stance and looks so much better than stock! No rubbing at all lock to lock and no issues so far either.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1404
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1405
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1407
Does anyone know if the front tire flaps can be removed? Does it affect driving negatively if so?
davidg4781
Looks good!
Yes, you can remove the front flaps. Relatively easy. I think I put the fasteners back because they were holding down the liner.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_8539
rm.builders
I purchased the VifoA229 Pro 4k 3 Channel Camera. I had the guys at BP Auto Sound do the installation and they did an amazing job. Front Camera, Rear, Camera & In cab Camera. I choose to have the unit hardwired to the fuse box.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240329_102215
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240329_102239
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240329_102245
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240329_102305
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240329_102309
davidg4781
Just curious, what's the purpose of the in-cabin camera? I'd hate to see myself scratching or picking something.
jkeaton
Greatest country on earth!
This one
15,000 mile oil change. Everything looking good. No coolant loss, so apparently what I was smelling a month or so ago was residual from the first water pump failure. Just FYI for those interested or questioning the oil pan capacity, attached a screenshot from Ford specifying the date the higher capacity oil pan came into play. Our 2022 manual lists the capacity as 5.3 qts but our build date was after Aug. 2022, so the manual is incorrect. Just an FYI.
Ford Bronco Sport What did you do TO your Bronco Sport today? Screenshot 2024-04-01 090918
Cjdicesare
Christopher
Springfield, Pennsylvania
Bronco Sport Outer Banks and Lincoln MKC
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_8247
Got the trailer hooked up and loaded. Ready to head out tomorrow.
Don’t let the Badland owners see this, or they will come and tell you that actually your 1.5L is in fact so inferior that you didn’t actually pull the trailer but the wind pushed it behind you by coincidence.
