CoastieN70
Lee
Travelers Rest, South Carolina
2024 Bronco Sport
Although I intend to keep my Bronco Sport mostly stock; I installed a Autostop Eliminator, no easy task when you have "fat fingers." What should have been a 15 minute job took much, much, much longer.
I also installed a set of Red Line Tuning Hood Struts! Much easier than the instructions lead you to believe, took 15 minutes total, from getting a couple of sockets and a ratchet to install, then clean up and putting the tools away. :)
Horse n Buggy
Stoge
Florida, USA
Custom Underground Graphics "Glade" decal installed. I asked for them to modify it to follow the hood line up to the A-Pillar where I had their topo Pillar graphics installed. Asked for Gloss black topo lines on a matte black background to match the Pillars
Ford Bronco Sport What did you do TO your Bronco Sport today? 1000006018
Ford Bronco Sport What did you do TO your Bronco Sport today? 1000006019
BLUEOVALRACER
Ohio
Installed Pedal Max on Monday on my Big Bend set the dial around 60 like it comes from JMS and removed the Dial!!And man what a difference throttle response is right now and now i don't miss the power of the 21 3.5 Eco Boost F-150 i had nearly as much!!
CancunBadlands
CancunBadlands
Cancun, MX
What about some nice black lettering! #cancunbadlands
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240211_140027
jimbopatt
Saskatchewan
Deuce ~ 2023 Bronco Sport Badlands
Stopped by the Insurance Broker and got a package that includes Replacement Ins and Windshield coverage if that counts. Ordered a custom plate "D3UC3" and picked up a new block heater cord. Also stopped at a local tire shop and chatted about wheel/tire packages and (with there not being a big selection in Gunmetal rims) ended up deciding I will just go with Cooper Discoverers again or try Toyo Open Country this time on the stock Gunmetal Badlands rims. I have the Discoverers on my half ton and they work great year round (keep it in 4wd in the city when icey) and they should work even better with AWD.
CancunBadlands
CancunBadlands
Cancun, MX
Replaced the original corner lights with the LED amazon ones.
Are the side marker bulbs LED?
According to the manual.
Replacing the Side Marker Bulbs
Side marker bulbs are LED and are not serviceable. See an authorized dealer if they fail.
If not LED, do the lenses pop off or does the bulb change have to be done from the back?
