SHOULD I DO IT ???? WORLD'S LARGEST CARWASH AT BUCCEES IS DOWN THE ROAD FROM MY HOUSE
I'm OCD with my vehicles and never use a carwash.
Mine goes through a touchless car wash when I feel it’s dirty enough. I wouldn’t take it through one with brushes.
Some people use car washes, some like to hand wash. Here's my take: If you want your car to get the best possible care then hand wash. The brushes in some car washes can put swirl marks and even light scratches in the paint's clear coat. These are much more noticeable with dark colors than lighter ones. A scratch would have to be pretty deep to be obvious on Cactus Gray.
On the other hand, if you find hand washing such a hassle that you don't wash as often as you should (environment dependent), then by all means take it through a car wash. A few minor swirls or scratches in the clear coat can be buffed out. Corrosion (rust) resulting from collected dirt and grime is difficult to control once it takes hold.
Deleted member 6350
Well unfortunately for some people I can no longer hand wash my vehicles due to a back injury but my ocd still gets to me, So far tho I’ve only been to the touchless ones.
Wolf256
Jane
Kingston, WA
2023 Bronco Sport Atlas Blue
Mine goes through the car wash every week or two. That said, I only use Laser wash touchless. There are no brushes to swirl the paint. There are no flappy swinging pieces to beat the heck out of my paint. The water and soap are sprayed at the vehicle and rinsed the same way. My bad back and hip greatly appreciate it.
gatornek
Miami
I'm on Team "Don't use an Automatic CarWash unless you have no other choice".
But there's literally like at least 10,000 other reasons to go to Buccees ... so don't let me dissuade you from the trip.
kshaw
Kent
Gaithersburg, MD
Two things to consider: The tall antenna on the back needs to be temporarily removed before going through a car wash. Our county requires that the water be recycled; is all the winter salt washed off cars being recycled, too? I hand wash mine or take it to my detailer.
PonyPowerxox
PonyPowerxox
Ruthie
West Houston
hum forgot about the antenae ....this is getting complicated....why can't BUCCEE be better LOL
really wanted to try out the car wash.....but honestly worried about swirl marks on the black windows in the back,,,,,hum......
Flash
Rather than take the tall antenna off temporarily before going through a car wash, I just replaced with a shorter one that won't break off. I like simple, one and done solutions to problems.
TnPapaw
Knoxville, Tennessee
2023 Bronco Sport Badlands
I had a car wash plan for years with a 2007 Pilot. The brushes didn't seem to hurt it, but the high pressure spray pitted the roof and caused the paint on the leading edge of the hood to flake. I used the wash at least once a week for about 10 years. I don't think an occasional wash would hurt, though.
kshaw
Kent
Gaithersburg, MD
I picked up one of these with a foam cannon and that makes it easy to clean cars. It is billed as having 320PSI but I do not think it goes that high. Use the foam cannon, let it soak for a while, rub with a towel mitt, and rinse off.
https://www.amazon.com/RYOBI-RY120350-18-Volt-Cordless-Cleaner/dp/B0895LD6LF/ref=asc_df_B0895LD6LF&mcid=7d8d5f39292934caa2d7435e8adecf9a?tag=bingshoppinga-20&linkCode=df0&hvadid=80745477064479&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4584345024598077&psc=1
