cprcubed
Parker, TX
There have been a few members here that have used the zip file without issue, so it should be fine. Cheers!
SeaJay
Georgia
2023 OBX Sport, Area 51, Hitch, Assist++
Please post screen shots of both folders on the USB Device so we can see the folder names, folder contents and file sizes (in step 3 you stated “…3 downloaded files” which would not be correct)
Some screen shots regarding my USB and what is on it when I head to the car.
Ford Bronco Sport Sync 3.4 Build 23188 Now Available 9/2/23 IMG_4253
Ford Bronco Sport Sync 3.4 Build 23188 Now Available 9/2/23 IMG_4254
@SeaJay your files and the one folder are a 100% match in filenames and file sizes to my 23188 USB Drive except two in the SyncMyRide Folder:
Yours:
5U5T-14G391-BS.tar.gz 1,511,368 KB
HB5T-14G386-VAB.tar.gz 25 KB
On my 23188 USB Drive downloaded from Ford Navigation Website 9/5/2023 is:
5U5T-14G391-CS.tar.gz 394,753 KB
HB5T-14G386-VBB.tar.gz 25 KB
I also checked to the 22251 USB Drive and it has the same 5U5T-14G391-CS.tar.gz 394,753 KB file and HB5T-14G386-VBB.tar.gz 25 KB file (other files differ from 22251 to 23188 just not those two).
EDIT: SKIP AHEAD TO POST #126
We need to find out if @cprcubed downloaded 23188 for a Bronco Sport from the Ford Navigation Website and if a Windows PC or an Apple computer was used.
This is the 9/2/2023 Post from cprcubed
Post #3:
https://www.broncosportforum.com/sync-3-4-build-23188-now-available/
As cprcubed mentioned, a number of people successfully used the provided Google drive files including this person that apparently installed on an F-350:
Ford Bronco Sport Sync 3.4 Build 23188 Now Available 9/2/23 1703300422413
SeaJay
Georgia
@SeaJay more info and I see the issue, the autoinstall.lst file is indeed looking for the 5U5T-14G391-CS file and in your SyncMyRide Folder you do not have that file… you have the 5U5T-14G391-BS file.
You will need to track down with @cprcubed if the provided Google drive contains the incorrect 5U5T-14G391-BS.tar.gz file or contains the correct 5U5T-14G391-CS.tar.gz (394,753 KB) file.
If Google drive is correct, you will need to find out how you got the incorrect 5U5T-14G391-BS.tar.gz file on your USB Device.
Once you delete 5U5T-14G391-BS.tar.gz file from your USB Device and add the correct 5U5T-14G391-CS.tar.gz (394,753 KB) file, then your 23188 installation should work ok.
@Dude thanks for your detective work! I’m away from home (in my Sport) for the holidays and will wait until I am at home base in the new year before attempting to work on this again. Merry Christmas to you and yours.
cprcubed
Parker, TX
I checked my zip file and it does have the 5U5T-14G391-BS.tar.gz file. Not sure what to do now since I used it successfully and some others here have also used it as well (SeaJay would be the only one that's reported any issues). Cheers!
SeaJay
Georgia
Yeah, who knows. Maybe a slightly different download is needed for a 23 OBX. Do appreciate everyone here trying to a help out. Maybe the Ford upload site will get back online for the new year! (Maybe Ford should come here for help!)
Jmuns
2022 Bronco Sport BL
@cprcubed .. can you check the autoinstall.lst file in your Google drive to see if it refers to the 5U5T-14G391-BS file?
if it does then SeaJay like all the others that used your Google drive files should be able to install 23188
(it just seemed odd to me that the 5U5T-14G391-BS file is present in your Google drive but is only odd because my download had a different file: 5U5T-14G391-CS with a much smaller file size - I don’t know why there would be this difference)
These are the files I had in mine after the download.
Ford Bronco Sport Sync 3.4 Build 23188 Now Available 9/2/23 Screenshot 2023-12-23 at 8.51.47 PM
cprcubed
Parker, TX
Here's what's in mine. Cheers!
Ford Bronco Sport Sync 3.4 Build 23188 Now Available 9/2/23 Picture1
I also have the CS file.. my 23188 download from Ford matches this set of files..
Ford Bronco Sport Sync 3.4 Build 23188 Now Available 9/2/23 1703435577143
My files in SyncMyRide Folder match @Jmuns … there are two different filenames in @cprcubed list (see Post #125 for the 2 filenames) which appear to be “older” files based on filenames but later when I get time I’ll use the Ford Sync decoder ring to check the 2 different files.
The autoinstall.lst file (one level up) controls the installation and since cprcubed files work for several people I am assuming autoinstall.lst matches the list of the posted Google drive files but since I don’t have the autoinstall.lst file from @SeaJay I am not able to see if that’s the source of SeaJay’s install failure.
cprcubed
Parker, TX
@cprcubed .. can you open the autoinstall.lst file in your Google drive to see if it refers to the 5U5T-14G391-BS file? I use Wordpad on a Windows laptop to open.
Here's the text:
; SYNC3 Consumer
Assembly Upgrade - Release
3.4.23188 - Only for
NonNav/NonEU assemblies.
[SYNCGen3.0_3.4.23188_PRODUCT]
Item1 = PU5T-14G386-BB
Open1 = SyncMyRide\PU5T-14G386-BB.tar.gz
Item2 = HB5T-14G386-VEB
Open2 = SyncMyRide\HB5T-14G386-VEB.tar.gz
Item3 = HB5T-14G386-VAB
Open3 = SyncMyRide\HB5T-14G386-VAB.tar.gz
Item4 = NU5T-14G381-AD
Open4 = SyncMyRide\NU5T-14G381-AD.tar.gz
Item5 = 5U5T-14G391-BS
Open5 = SyncMyRide\5U5T-14G391-BS.tar.gz
Options = AutoInstall
[SYNCGen3.0_ALL]
Item1 = GB5T-14G386-AE
Open1 = SyncMyRide\GB5T-14G386-AE.tar.gz
Item2 = LU5T-14G386-CA
Open2 = SyncMyRide\LU5T-14G386-CA.tar.gz
Options = AutoInstall,Delay,Transaction
Is there a difference between files for Nav and NonNav vehicles on the files? It does say "
Only for NonNav/NonEU assemblies". Cheers!
magicbus
Nantucket
Rivian R1T, Volvo XC90 Hybrid
Here's the text:
Yes there is a difference and the tar file only includes the files called out in the autoinstall script. The only differences seem to be Open3 = SyncMyRide\HB5T-14G386-VBB.tar.gz which is Open3 = SyncMyRide\HB5T-14G386-VAB.tar.gz in the non-nav version and the addition of Item5 Open5 = SyncMyRide\5U5T-14G391-BS.tar.gz .
Here is the Nav autoinstall list:
; SYNC3 Consumer Assembly
Upgrade - Release 3.4.23188 - Only
for Nav/NA assemblies.
Item3 = HB5T-14G386-VBB
[SYNCGen3.0_ALL]
Options = AutoInstall,Delay,Include,Transaction
