Near redline at WOT - highway merge
Blooey
Somewhere in New Jersey
2023 BS Heritage Limited, 2023 BS Badlands
Driving in Normal mode - '23 Badlands - had to really floor it getting onto the highway as the guy coming up on my left decided to not let me in at the last moment. RPMs went up to about 6000 for a few seconds. I sometimes hit 4,500 or so in less urgent situations but generally don't overdo it. Should I be concerned about any damage/excess wear or is the occasional near-redline to be expected?
BravoAlpha
Oklahoma
hope you smoked him
The system has monitors and limits to protect itself. It simply won’t allow you to exceed preset parameters.
Regarding damage, @BravoAlpha is correct. The powertrain control module (PCM--computer that controls the engine) constantly monitors environmental factors and engine sensor data. When you make a maximum power demand (put the accelerator pedal on the floor) the PCM delivers the maximum power available under the conditions. Unless it is malfunctioning it will not allow power output to exceed safe limits.
Regarding excess wear, higher power output equals greater engine wear. Your engine was designed to accommodate brief maximum power output on occasion--for exactly the situation you describe--but prolonged, frequent high power demand will add significantly to engine wear and decrease longevity. TANSTAAFL.
sajohnson
Sherman
MIDDLETOWN, MD
I completely agree, but thought I'd add some anecdotal evidence...
When I was commuting daily, I frequently drove my cars like I stole them. Maximum acceleration, shifts just shy of redline (hit the rev limiter a couple times when I was not paying close enough attention). A lot of high rpm operation.
The '93 Nissan NX2000 has 250,000 miles, the 2002 WRX has >200,000 -- 100,000 at Cobb Stage 2.
Both still run fine.
That said, I'm sure they would both run even longer if they had been driven more gently -- but in my experience, other stuff begins to fail long before the engine goes. In fact, I've never had to replace an engine in almost 50 years of lead-foot driving.
My sense is that there is a LOT of safety cushion built in.
Barry S.
Barry
Holly Springs NC
That's because you live in New Jersey. Here in North Carolina, other drivers actually slow down and wave you in. ?
Tigger
Tigger
Illinois
This reminds me of the first time I drove in Boston. I turned on my blinker to merge and my brother said, “don't use your blinker in Boston; it shows a sign of weakness”
Barry S.
Barry
Holly Springs NC
It's actually a law in North Carolina that, if someone signals a lane change, you slow down and let them in.
sajohnson
Sherman
MIDDLETOWN, MD
My wife and I have driven all over the country and it is amazing how the norms vary.
We do our best to avoid urban areas -- specially during rush hour. Rural areas are generally fine.
In Chicago, it means speed up and close the hole. That gives them more space behind you. Maybe.
Rogerthat898
Roger
I'd like to see this law.
This would cause a horrible traffic flow issues.
