Fuel Injector Recall
llee1975
llee
I am curious, has anyone had any issues after they took care of this recall on your vehicle? I knnow it was only to install a drain tube. Reason I am asking, I had this recall taken care of in early summer and recently I am having some sputtering and the engine feels as if it is bogging down a bit. Anyone else dealing with this issue? I know it may just be irony, but sometimes you have to wonder. I just hit 30K miles on my 2022 Big Bend.
Alfa 2407
Thomas
Sounds like injectors, or electrical, it could easily be related, most common signs of injector leak that I've read is smell of gas and significantly reduced fuel economy, anything less than 20 should be cause for concern
Take it back to the dealer that did the recall and have them check it all out.
I heard here that a mod to the software was also performed related to the drain tube install.
Yup, not a recall for the injectors.
As @Bucko noted, this recall included software changes. Your issue may be related to those changes. Another trip to your service department is in order.
o0260o
NJ/NYC
2021-2025 BroncoSport (sold)
So if you give it the beans and your 3 cylinder suddenly acts like a 2 cylinder being all jerky and stuttering... that might be an ignition coil. It's very noticeable when 1/3 of the engine is gone. I had mine fail around 25k.
I also find these engines sputter and bog down sometimes right after being filled up with gas.
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
timeline aug 2023 notification of recall
march 2024 call from dealership
mobile service scheduled to resolve drain tube recall issue
well that was quick
wish me luck boys
Ford Bronco Sport Fuel Injector Recall 1711047038274-ca
Ford Bronco Sport Fuel Injector Recall 1711047142840-9
Kong reporting back
thumbs up gang
no battery removal for install
modules sync'd updated and happy
So, there is a recall to correct something on the older drain tube recall?
Do you have a TSB number for this latest recall on the old drain tube recall?
Major Kong
Major
"So, there is a recall to correct something on the older drain tube recall?
Do you have a TSB number for this latest recall on the old drain tube recall?"
ancestry.com traces my origins back to S. Australian lands of Gibber
there are moments when I revert back to my native tongue
straight up gibberish with a slightly off center babble dialect
as one might imagine body posture and hand signs play an important part
so to answer your question...........Nes
22S73 - 1.5L Oil Separator Post FSA 22S21 Inspection Underhood Fire Reports
service tech guy managed to decipher my gobbldygook comms fairly well
Ford Bronco Sport Fuel Injector Recall 1711113975044-if
TresAraras
Western NC
2018 Kia Soul !
I received email on 3/9 for the drain tube and PCM reprogramming...
recall #24S16. Repair completed 3/25. Woke up to dead battery 2x since service. Good times.
