ErikaFrzn
Erika
‘22 Bronco Sport, '15 Explorer, ‘22 Trail Boss
Whatd that end up running you and did you have a shop do it? I need to eventually put a bike rack on it.
It ended up costing $300 all in….$180 for the hitch from Summit Racing and $120 for the install. No wiring harness since I also just wanted it for a bike rack and basket. What bike rack you have in mind? I am having a heck of a time trying to figure out which one to get.
also just added some low profile crossbars from Amazon, Curt hitch cover, and lock.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_9330
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_9336
Colonel Angus
Dean
New York
I'm not usually a fan of white letter tires because they are a PITA to keep clean. That wheel and tire combo you are running though looks amazing. Very sharp.
It depends on your needs. How many bikes? Do you need access to the liftgate when the rack is installed? How high can you lift your bike? Do you need locks?
There are probably more questions you need to answer, but once you have a list you can start narrowing down your choices.
ErikaFrzn
Erika
thanks, I have always liked the white letters myself, but they really are difficult to keep clean. I actually regretted my decision for a little while but, after a good scrub, that faded.
ErikaFrzn
Erika
I have narrowed it down slightly… but they all seem to be very expensive. Particularly a platform style, 2 bike, and tilting feature isn’t necessary but would be nice. Not to mention, I am only 5’1” so I can’t lift the bikes too high. Also, I am trying to find one that won’t touch the frame, but that seems to put it in a higher level price range.
Apologies for taking this off subject, but if anyone has one with similar specs that is $300 or under and are happy with it, I would love to hear about it.
Thanks!
Thanks!
This rack is well reviewed at Amazon. It holds two bikes, can tilt to allow access to the liftgate, and includes locks to prevent theft. You mentioned a concern with touching the frame. I'm not sure why that would be an issue as long as the locking bar is padded. But if that is a concern you can purchase a separate adapter bar that clamps to the seat post and the handlebar riser.
Colonel Angus
Dean
New York
New Goodyear Wrangler Workhorse AT's 245/65/17. What a difference from the stock Conti's. Just the right amount of aggressiveness. Like the extra width over the 225's. Tire guy thought they were gonna rub. Told him no, I've done my homework. No rub but they fill the wheel well nicely. Very happy how they look and ride. They filled them to 33 psi but I like to run a little higher. Around 35-36 psi.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2186
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2184
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2185
Alfa 2407
Thomas
I just did the same yesterday after my front right had a blowout on the inner sidewall, same conversation with the tire guy, he wasnt too pleased when i told him he was wrong, even less so when ihe realized he was wrong, was about to post when I saw this, BFG KO2s same size
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230908_075251
Colonel Angus
Dean
New York
Looks great! Have 315/70/17 KO2's on my F-150. Excellent tires.
MNBronco
Minnesota
2023 Bronco Sport Outer Banks
Side ladder project
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230908_115914
Nice, I'll bet that makes it much easier to load. I'm currently using a door step (for our Sorento) have only used once so far, worked fine. I've not tried it (or a roof rack yet) on our Bronco Sport. I can see how a ladder would be so much better.
Wolf256
Jane
Kingston, WA
2023 Bronco Sport Atlas Blue
Haven’t done it yet, but the following items were delivered today.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0154
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0156
Not the best second picture, but the fold down headrests for the backseat came in today. I’ll find out tomorrow how close the color is. I’ll even try to remember to take pictures.
Not
ajm0903
AJ
CT
Bronco Sport Badlands, Miata
Intake and borla car back installed
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0694
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0692
