Goat modes
Hobbit
Bibby
Bc
Ford sport bronco
When changing between modes will it reck the car if ur moving? Is the nose normal ( high pitch)?
Bill G
San Gabriel Valley, CA
Don't know about the noise but, no, shouldn't hurt to change modes on the fly. Just make sure you're not going into a mode that shouldn't be used under your current conditions (mud/ruts on paved road, etc). Change between normal, eco, sport on the fly all the time
Hobbit
Hobbit
Bibby
Bc
Ford sport bronco
Ok thanks I was changing between normal and eco. I did learn eco is not for HWY driving.
Bill G
I use eco even on the hwy much of the time -- just have to remember it'll take a while to pass unless you really "kick it" which nullifies the "eco" part
I don’t believe ECO is beneficial on the highway. It works by decreasing throttle response and upshifting sooner to keep RPM as low as possible. When cruising on the highway you’re already in the highest gear, and downshifting to accelerate faster to pass can save fuel in some situations because you are demanding higher power for less time.
My use pattern is about 60/40 highway/city, and I saw no improvement in fuel economy using ECO. All my data is available at this link.
Bill G
Mark, you’re absolutely right. Only reason I leave it in eco here in SoCal is traffic. Keeps me from having to remember to switch modes constantly in the interminable traffic jams on the valley fwys, constantly going from 65-70 to 3-5 mph and back, plus I drive the streets a lot just to avoid the fwys.
Barry S.
Barry
Holly Springs NC
With all those complicated mathematical equations, when do you find time to drive??
davidg4781
I've started to wonder if doing a slower acceleration in town to 35 mph is more economical than a moderate acceleration.
I'm too lazy to do the math but I'm thinking a longer time at a low mpg vs shorter time at a lower mpg. The difference might be negligible.
You definitely can use Eco for hwy driving.
You can, but does it do what it's supposed to? My testing says it's ineffective for highway driving. I'd love for someone else to do the same testing. I tested over three tanks to average out all the factors that might affect fuel economy, and my results suggest ECO doesn't improve fuel economy for mostly highway driving.
Hobbit
Hobbit
Bibby
Bc
Ford sport bronco
R any of the hwys hilly or is it all flat like city driving. I live in a small county town that isn’t that flat in northern British Columbia
AmazingSieve
Denver
Bronco Sport Badlands
I think you and I discussed this and I was pretty adamant about my opinion, but you are right about this. Now I think it can help in stop and go city driving but it is just engine mapping. Having a lighter right foot will do the same thing.
sajohnson
Sherman
MIDDLETOWN, MD
A related question -- I was driving the BS BL in manual mode the other day and it was working as expected, except it would not go higher than 7th gear -- even downhill at 55-60 mph with no load. I never saw 8th gear.
Is that normal?
RodNSA
Rod
San Antonio, TX
Ford Bronco
I typically get 2-3 more mpg on trips over 3-4 hrs where I'm driving continuously without stopping. I've tested this many times driving from my city to visit my daughter who lives over 3 hrs away where I'm driving 100% on a high speed tollway ... Eco is my winner each and every time.
Is that normal?
63 mph. It'll go into 8th at 63. Well, mine does anyway. You can then slow to around 58 and it'll stay in 8th as long as you don't step on the pedal.
