NEW PRODUCT! Bronco Sport 2 Inch Level Lift $449
Status
Not open for further replies.
austin3.16
Austin
And you got your front and rear level or you kept the rake with that setting?
I’m sure I’ve set my spring collars higher than that pic and my rear end is barely level with the front. I feel like the springs are weaker (or shorter) than they should be if this kit was supposed to deliver a 2” rear lift
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
www.flatoutsuspension.net
2022 BS OBX
What is the free length of your spring you received from us?
B5G4B
2022 BRONCO SPORT
Kept the rake. Rear set higher.
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
2022 BS OBX
I think the paperwork said 11”.. I didn’t measure them out of the box before installing though.
Someone packed the wrong spring, I’m sorry about that, you should have a 12”. PM me your name or order #, I’ll get a set of springs headed your way with a return label for those other ones.
austin3.16
Austin
Ahhhh that explains so much lol I’ve been going crazy trying to figure out what I did wrong. Will PM
austin3.16
Austin
Hey,
I’ve installed the new (proper) springs and they definitely provide more lift in the rear which is great! I’m having a bit of trouble getting an even lift between left & right in the rear. The attached pic is my left rear and the red arrow measurement to the collar is 2-1/8” while the collar on the right rear is set to 1-5/8”. This is giving me close to 1/2” between front and rear. But the left & right are still about 1/4” apart in ground height. Any advice or suggestions why my collars need to be so different?
TIA,
Austin
Ford Bronco Sport NEW PRODUCT! Bronco Sport 2 Inch Level Lift $449 IMG_0083
austin3.16
Austin
I learned about pre load on suspension bushings and took the time to undo that as well as torqued all the bolts properly. Got both collars set to 1-5/8” and the lift is looking pretty good now..
here’s a little before after which I really like:
Ford Bronco Sport NEW PRODUCT! Bronco Sport 2 Inch Level Lift $449 1188FA1E-FC09-4AEF-9A77-6065F6788A61
jhnvan
James
bronco sport
I'd like to know if you would be willing to sell the rear kit only? I need the springs and adjustable perches only...
Status
