Auto Hold System Fault
Fernata
Fernata
North carolina
2021 bronco sport
Let's add one more issue to the unresolved ones.
The back up moaning, the noise and shudder when turning etc.
I seem to remember last year this may have popped up but my daughter was driving and it went right away, so didn't get to make a notation of it.
Do I go to dealership so they can say they can't duplicate it? Like all the other issues.
Still waiting for ordered brake pads and fluid, for differential I guess.
Or should I just go get the Bronco wrapped with all issues noted on it?
MGM
I just had the "shudder when turning" fixed at my dealer. Change differential fluid and add friction modifier. Shudder and vibration at low-speed turns gone. There is a TSB on this.
Fernata
Fernata
North carolina
2021 bronco sport
They acted like I was nuts when I came right back after oil change and tire rotation. I swore they didn't tighten lug nuts it was so bad.
They couldn't duplicate, but then said they were ordering fluid. Waiting
I think this may have something to do with the back up issue though.
Might be one of these TSBs & there other similar but just with different TSB #s, this is not a complete list and other Bronco Sport models and model years might be affected.
SSM 49571 - 2019-2021 Edge/Nautilus, 2020-2021 Escape/Corsair, 2021 Bronco Sport - AWD - Chatter/Shudder During Low Speed Turning Events
( also see: https://www.broncosportforum.com/forum/threads/‘21-big-bend-rear-end-clunk.8711/ )
Some 2019-2021 Edge/Nautilus, 2020-2021 Escape/Corsair, 2021 Bronco Sport vehicles equipped with all wheel drive (AWD) may exhibit chatter/shudder during low speed turning events due to fluid contamination. Drain and refill the rear drive unit (RDU), refer to Workshop Manual Section (WSM) 205-02. Drive for 8 km (5 miles) in stop and go conditions with right and left turns and re-evaluate. If the issue is still present, continue with WSM diagnostics. For claiming, use base (4000) causal part.
TSB 23-2041
NHTSA Number: 10232491
Moan Noise In The Rear Brakes When Vehicle Is Driven In Reverse (R) On Cold Weather And/Or High Humidity
Supersedes 22-2326
https://www.broncosportforum.com/forum/threads/2023-heritage-limited-reverse-groan.8772/
https://www.broncosportforum.com/forum/threads/so-many-problems-need-to-find-help.8591/
TSB Number: SSM 51459
NHTSA Number: 10233742
TSB Date: March 17, 2023
Summary: Some 2020-2022 escape/corsair, 2021-2022 bronco sport, and 2022 maverick vehicles built on or before 23-mar-2022 may exhibit a hard, stiff, and/or difficult to turn condition due to a lack of power steering assist during engine start-up …
