So it happenedšŸ˜¢ā€¦..
Must be a typo.
The REF date in the Ford document is listed as December 19, 2023
https://static.nhtsa.gov/odi/tsbs/2023/MC-10233848-0001.pdf
Good news that the Op's BS was repaired.
Right that 2022 date might relate to the 22S73 PCM Programming and Drain Tube Installation (Recall) which needs to be have been completed prior to the no-cost, one-time replacement (if needed) of all three high-pressure fuel injectors as discussed in that PDF.
Sleddog
Bob
2022 Bronco Sport Cactus Grey.
I believe the E part number for the injector is the latest version. This was discussed in post 69.
Yes. And the A part as discussed earlier cannot be purchased.
Yes they replaced all 3 injectors. I neglected to ask if they were the same part or different. I attached the invoice, someone may know based on the part number.
Ford Bronco Sport So it happenedšŸ˜¢ā€¦.. IMG_0366
Thanks for sharing. If possible, can you ask your service department if they can give you any details about the difference(s), if any, between the injectors they installed and the ones they removed? Forum users are trying to ascertain if the injectors installed at the factory are materially different from the replacements.
Sport Fan
2023 Bronco Sport HLE
Sorry to hear it happened!
Did they reinstall a drain tube?
I just had the Fuel Injector Recall fix completed on my 2021 OB this week.
Good luck in the future!
AlpharettaOuterBank
kdawg
Georgia
Outer bank
Yeah I’d like to know the mileage too. Also did you have the recall done before it happened? I thought there was a program installed that was supposed to warn you if your car started leaking fuel.
it can happen if youve HAD the recall done???
Yes. The recall isn’t meant to eliminate the possibility of a fuel leak. Read through this entire thread. There’s a lot of info about this on the site, but you’ll need to spend some time searching for it.
Sport Fan
Are the replacement fuel injectors a permanent fix, OR does Ford also reinstall a drain tube because the replacement fuel injectors may also fail?
Sorry, no disrespect intended, but this subject has been hashed and rehashed so many times it’s no longer hash. Between the PDF @Dude linked to and just this thread alone, you should be able to find the answers you’re looking for. Let me know if after reading it still doesn’t make sense and I’ll try to help.
Sport Fan
Sorry, no disrespect intended, but this subject has been hashed and rehashed so many times it’s no longer hash. Between the PDF @Dude linked to and just this thread alone, you should be able to find the answers you’re looking. Let me know if after reading it still doesn’t make sense and I’ll try to help.
No offense taken.
My thanks to Dude for the PDF link - it was informative.
But, the question still remains whether or not Ford reinstalls a drain tube when replacing the fuel injectors.
No offense taken.
But, the question still remains whether on not Ford reinstalls a drain tube when replacing the fuel injectors.
You are welcome and in the PDF it is stated that the recall work (drain tube and PCM Programming) is a prerequisite.
but you stated ā€œreinstallsā€ and that implies to me that you are asking if the drain tube is removed, the E part fuel injectors are installed and the drain tube is put back on. Is that what you are asking?
Sport Fan
YES, that is EXACTLY what I'm asking! Thanks for asking for the clarification!
I don’t know the specific order of installation but in the end the drain tube and related PCM Programming is in place along with the E part fuel injectors as stated in the posted PDF. The dealership service department can answer your specific question on the installation order.
Sport Fan
Thanks for the direct answer!
Since a drain tube will be reinstalled/in place along with the replacement fuel injectors, I am not reassured that the replacements won't also fail - but if the replacements fail, Ford will not replace them again at no cost.
