I think if you reply to his thread , he will be able to answer your questions.Got a link for that? I don’t see it it his threads. Thanks in advance
Cooper discoverer AT3 is discontinued. That was my original pick.The 235/70/17 (30") size works, but there are very limited selections in that size. The Goodyear Wrangler Workhorse AT that JRL used is one. The Yokohama A/T GO15 is another and has been used by folks on this board with positive reviews. Others that run this size are the Firestone Destination A/T2 and The Cooper Discoverer AT3. The rest are HT tread patters. None of the big AT names like BFG, Toyo, Falken, Nitto, etc make this size, which is odd. If one of those is what you want, then your only options are the 245/65/17 (29.5") or the 235/65/17 (29").
Check post #19 from meanderthal .I think if you reply to his thread , he will be able to answer your questions.
Thank you sir .
If you try to push past 235/70/17 and that will be 245/70/17 you very possibly will get some rub on the liners that extra 10 mm on width might just push you over the rub zone . Just my opinion. Right now I have about 1/2 inch clearance .Ah okay I understand thanks and yes I’m certain the badlands and FE have the same suspension. So if it worked for you it should work for me.
Is it close absolutely for sure , but that only counts in horse shoes, that was sort of a play on words. HORSE ? SHOES I-will silently depart now .If you try to push past 235/70/17 and that will be 245/70/17 you very possibly will get some rub on the liners that extra 10 mm on width might just push you over the rub zone . Just my opinion. Right now I have about 1/2 inch clearance .
Do we know what the original diameter is, at least on a Big Bend?The 235/70/17 (30") size works, but there are very limited selections in that size. The Goodyear Wrangler Workhorse AT that JRL used is one. The Yokohama A/T GO15 is another and has been used by folks on this board with positive reviews. Others that run this size are the Firestone Destination A/T2 and The Cooper Discoverer AT3. The rest are HT tread patters. None of the big AT names like BFG, Toyo, Falken, Nitto, etc make this size, which is odd. If one of those is what you want, then your only options are the 245/65/17 (29.5") or the 235/65/17 (29").
My Goodyear are 30 inch exactly , my stock tires came with falken wildpeck 235/65/17 they are 29 inch. I think a Big Ben would be 28 inch .’Do we know what the original diameter is, at least on a Big Bend?
I did 245/70/17 kanati Trail hog A/T and LOVE them. I live in rural Wyoming and needed a 10ply. They did fine no rub for a day before the lift but I had the rough country put on because of clearance issues for the 2 tracks on our farm.Now that there are enough people who have upgraded tires, these two sizes rise to the top for biggest tire you can fit with no mods. Would like to hear from people who have done it.
Here is a measurement of the Pirelli Scorpion:Do we know what the original diameter is, at least on a Big Bend?
The OEM diameter on a BB would be 28.5" (225/65/17). On a BL it could be either 28.5 (225/65/17) or 29" (235/65/17 - if the optional Falkens are selected). On an OB it is still 28.5" (225/60/18).Do we know what the original diameter is, at least on a Big Bend?
