In my mind also. Starter/alternator or some minor connection issue with the battery.My first thought with that amount of errors at one time is to charge the battery and then get it tested.
Next couple of weeks I'll take her in.
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.I am currently going through this with my wife’s Bronco. Lit up like a tree, parking light is flashing, engine start/stop button flashing. I disconnected battery and waited and still not wanting to start. Got someone to jump me and nothing happened…….waiting for a tow ugh
I eventually pushed and held the start button after a while. That seemed to reboot the system and the Bronco started. The dealer reprogrammed, believe it or not, the entertainment system. That has workedI am currently going through this with my wife’s Bronco. Lit up like a tree, parking light is flashing, engine start/stop button flashing. I disconnected battery and waited and still not wanting to start. Got someone to jump me and nothing happened…….waiting for a tow ugh
You need to highlight the Ford Motor Company avatar (post #5) and select "start conversation" to give them this information.Vin: 3FMCR9D97MRB29595
My Dealer is: Family Ford
410 East Island Highway
Parksville BC V9P 2G7
the dealer was very helpful and accommodating. Provided a loaner car from the time I took the Bronco in 03/12
until I picked it up on 03/14.
That's horribly frustrating.Update: I had the car towed to dealer. The car miraculously started for them and they found no error codes and everything was fine. I drove the car home and then the next day it died again and I had all sort of glitching lights and weird chimes. Could not get it jumped and now it got towed again to a different dealer to see if they can find anything. I’m thinking there’s a short somewhere
This is usually a sign of a weak/discharged/bad battery. Charge the battery and see if that fixes it.Update: I had the car towed to dealer. The car miraculously started for them and they found no error codes and everything was fine. I drove the car home and then the next day it died again and I had all sort of glitching lights and weird chimes. Could not get it jumped and now it got towed again to a different dealer to see if they can find anything. I’m thinking there’s a short somewhere
Thank you. I’m hoping all we need is a new battery. It’s only a year and half oldThis is usually a sign of a weak/discharged/bad battery. Charge the battery and see if that fixes it.
You'd think the battery would be just fine if it's able to flash lights and turn on/off the dash!
The electronics that run the car are pretty sensitive to lower voltage. While everything lights up, that does not mean that all other systems have the power they need to function properly. Several people here who drive infrequently or drive very short distances have had issues with the battery getting "weak". Sometimes, once they start a routine of charging the battery when it is parked, the issues they have go away. To me, the primary symptom seems to be that all of a sudden there are a lot of error codes/lights that don't seem to be connected for any reason.You'd think the battery would be just fine if it's able to flash lights and turn on/off the dash!
I'm assuming you are going to show the service advisor this video.
Still amazes me that a weak battery can flash headlights on and off, along with dash indicators. Seems silly that this would be allowed to take place on a vehicle that determines the battery is weak/low.The electronics that run the car are pretty sensitive to lower voltage. While everything lights up, that does not mean that all other systems have the power they need to function properly. Several people here who drive infrequently or drive very short distances have had issues with the battery getting "weak". Sometimes, once they start a routine of charging the battery when it is parked, the issues they have go away. To me, the primary symptom seems to be that all of a sudden there are a lot of error codes/lights that don't seem to be connected for any reason.
ChatBS is being rolled out in 2028 that will allow the vehicle to think better about what it is doing and avoid these situations.Still amazes me that a weak battery can flash headlights on and off, along with dash indicators. Seems silly that this would be allowed to take place on a vehicle that determines the battery is weak/low.
Kind of like describing to the doctor that my arm hurts when I twist it. The response is that you should not twist it. If the battery is weak/under charged, then don't provide actions that will weaken it more.
Not long after that, all vehicles will begin culling their drivers and passengers.
That’s hilarious!! You made my morning!ChatBS is being rolled out …
