I've not seen those placed on the c- column before. Looks really sharp.I added the Bronco wording, black on black. To both sides of course
Thanks. I haven't either but I wasn't sure how well they'd stick on the paintwork ceramic coating and I also kinda thought, maybe less is more (black on black). I experimented and temporarily placed them, stood back and took a look and liked them so went ahead.I've not seen those placed on the c- column before. Looks really sharp.
You want an engine to last between 150 million and 20 billion miles? I don't think that's ever going to happen, regardless of anything you might do.[...] I want this engine to last between 150000 thousand to 200000 hundred thousand [...] I will change it every 5000 thousand with full synthetic. [...]
Do you have any pics? How do you like them?Nice warm day in Syracuse, so I got my door sill protectors installed.
Looks good but how do you connect CarPlay? I'm assuming it doesn't work through MagSafe?I put in a Spigen dash mount that holds a first party Apple Magsafe puck.
Pros:
Cons:
- 15W charge speed. The car mounts that will wirelessly charge an iPhone at 15 watts are certified Magsafe accessories. For car mounts, the only fully out of the box option is this one vent mount from Belkin for $100. The alternative is to get a mount like this that has adhesive and you add an Apple Magsafe puck to it. (Non-certified magsafe devices, iPhone will only charge at 7.5W wirelessly - any Amazon listing saying "Magsafe compatible 15W" on other products is misleading you. It'll offer 15W Qi charging to devices that want that rate, but the iPhone won't take more than 7.5W unless it's Magsafe certified, and that's barely better than the 5W of the charging mat that is factory installed in certain BS trims/packages)
- Having the secondary screen next to Carplay is useful for certain non-distracting apps - for example, when Waze is open in Carplay, if Waze is on the phone, you can see more than just the next turn, or the list of traffic/hazards/police/etc., or if you have a bluetooth app for a radar detector (YaV1, Escort Live, etc.) again useful.
- Having the phone up high and close to the start/stop ignition button means I'm less likely to forget it than the built in wireless charger (which again is much slower - the one built into the BS is 5W, this does 15W), or with wired Carplay. Easier to stick on for charging than fishing for the cable too.
- Apple doesn't make the Magsafe puck in anything except white, so the white cable sticks out. I'm OK with this tradeoff, although if the back of the screen (or dash behind it) had a USB-C, that would have been nice. (Sync 3 does not like the puck being plugged into the USB-C port below the radio either - for max charge rate, you need a 12V USB-C PD adapter capable of charge rates at or above 9V/2.56A... not hard to find these days, but you'd want to pick an adapter of that profile).
- It's slower than the theoretical max charge rate wired on newer iPhones; however, research suggests that it's still faster than the USB-C port below the radio. I haven't measured it myself, but for the Big Bronco 6G, people tested the port and the USB-C port seems to max out at 5V * 1.79A = 8.95W, even for phones capable of drawing more. If you were to plug into a 12V DC adapter with a USB-C PD rating of sufficient spec, iPhone 13/14 Pro Max models max charge rate is 27W, and non-max 13/14 Pro models max out at 20W.
Ottocast U2-air wireless carplay adapter. I had a carlinkit 3.0 in my prior car (2015 Ford Fusion, I had upgraded the radio from MyFord Touch to Sync 3) for wireless carplay.Looks good but how do you connect CarPlay? I'm assuming it doesn't work through MagSafe?
