Bronco Blue
Brian
Illinois
2022 Ford Escape
I added two window stickers and had my letter overlays I bought from Ford put on today. The letters are Velocity Blue, the same color as my BS. I was worried they wouldn’t look good for that reason, but I felt it would look cool because I’ve seen from others who’ve done it, that the letters have a white outline. I’m very happy with the results!
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_4403
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_4402
Winds of Change
Chicagoland
2023 Bronco sport
Winds of Change
Chicagoland
2023 Bronco sport
On 245’s, the 20mm (.79ā€) are said to work. I’d be hopeful for the 1ā€ (and possibly the 1.25ā€)
Good luck!
Nice Kent. I put a window sticker in my previous Sports that were Area 51 but I can’t decide if it would look right with the Yellowstone and white roof.
A decal might look alright if you match the red on the grille.
Winds of Change
Chicagoland
2023 Bronco sport
Installed some grill aka Raptor lights today. One of them is slightly crooked but it still looks good.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0737
I wish AVS would make the Aeroskin2 like the one for the 6G Bronco with the lights built in.
Winds of Change
Chicagoland
2023 Bronco sport
Fender flare Friday! Some have had problems with these not staying on. I installed these myself, and I can tell you that you have to use considerable force to push the flares in far enough to get the installation clips to engage in the slots in the fender flares. If you had these installed on your car you might check to see if the clips are properly seated in the slots.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230410_090851
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230410_090826
Good to see someone else with the optional wheels.
Winds of Change
Chicagoland
2023 Bronco sport
Installed a J&L OSC 3.0 Oil Separator
Quick an Easy Installation, I would also advise that you use Blue Loctite
on the Nut from the Alternator Bracket.
Ford Bronco Sport What did you do TO your Bronco Sport today? 6BF64CAE-25A6-4AA0-BE74-9EC3BFA8D37D
Ford Bronco Sport What did you do TO your Bronco Sport today? 315A6344-1EA3-4053-B993-14E4B295810B
I have heard 2 different things on these oil separaters. If there is oil collecting there is something else going on? Whats the story?
Winds of Change
Chicagoland
2023 Bronco sport
Added a little flair to Juice today. Got the obligatory fender script badges and horsey on the tailgate. Also replaced the valve stem covers thanks to the idea from another forum member. Going by local Ford dealer tomorrow to order a Aeroskin II.
Ford Bronco Sport What did you do TO your Bronco Sport today? E3BE2C54-4326-459D-8E74-97406236AA57
Ford Bronco Sport What did you do TO your Bronco Sport today? EB925FD8-B1A8-433F-A836-87568FB764F7
Ford Bronco Sport What did you do TO your Bronco Sport today? CA5B19B4-1869-4555-9E0F-D972D1B8A810
Ford Bronco Sport What did you do TO your Bronco Sport today? B032D2FC-6B16-47AC-BF97-1915C04EAA7D
Ford Bronco Sport What did you do TO your Bronco Sport today? 763925A4-A301-403B-AA77-DBFA1FAC54E5
Those valve caps can corrode and be difficult to remove fyi. I saw it happen.
Winds of Change
Chicagoland
2023 Bronco sport
These are the plastic ones. I think the issues are with the metal ones.
I did not know there were plastic caps with designs.
Tigger
Tigger
Illinois
Winds of Change
Chicagoland
2023 Bronco sport
Ford Bronco Black ABS Plastic Tire Valve Stem Cap Covers (Pack of 5) https://a.co/d/gL3s1uV
As you can see here, you have a plastic or chrome option. The chrome ones suck and get stuck.
$17.95 wait I need a few more cocktails first.
Deleted member 6350
To me it’s ā€œBetter to be Safe than Sorryā€ haven’t got to many miles on this one, only about 300, but my BigBend that I traded in with 16000 thousand miles I got maybe 2 tablespoons worth of oil in those 16000 thousand miles, I just don’t like the idea of returning that oil back into the pan. I want this engine to last between 150000 thousand to 200000 hundred thousand , so call me a little anal or ocd. It’s one of those ā€œDamn if you do Damn if ya don’t. I believe in being proactive not reactive. Besides it gives me something to do. I also believe in preventative maintenance. Just like I did to my BigBend, I’ll change my oil at 500 miles then again at a 1000, then I will change it every 5000 thousand with full synthetic. Good Luck in whatever you decide, I’m not an engineer but I think there is no ā€œwrongā€ answer.
