- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,731
- Reaction score
- 13,153
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
- Thread starter
- #1
Picking up where we left off from this thread:
For proof, watch this slow-motion video of a 4-stroke engine in operation. The cylinder is made of acrylic allowing us a peek at the processesāsuck, squeeze, bang, blowāas they occur. Pay special attention starting at around 18:10, where each of the processes is labeled to make it clear what's happening. Following the combustion stroke you'll see the exhaust gases rush out of the cylinder as soon as the exhaust valve opens. It's the pressure differential due to the combustion process, not the piston motion, that results in movement of the exhaust gasses.
Ahhh. I think I see the disconnect. You'll often hear people say that an internal combustion engine is nothing more than an air pump, but that's categorically wrong. It's not the piston moving up during the exhaust stroke that causes burnt exhaust gases to exit the cylinder. If that were the case modern engines would be even more inefficient than they already are owing to pumping losses. Pumping losses are really quite low, especially at or near wide open throttle where the turbocharger is generating the greatest boost. So, it's not the piston's motion that generates the pressure in the exhaust system, it's the pressure differential between the hot gas in the cylinder and the relatively cooler exhaust manifold.The combustion that happens in the cylinder goes toward driving the pistons. It does not do anything for the turbo. You are correct about the turbine engine requiring the combustion.
The pressure delivered to the turbine side of the turbo is delivered by the pistons. The air happens to be hot, but it doesnāt add anything to the work coming out of the turbo. If the hot air was adding work it would have to lose a significant amount heat to add work to the turbo.
Your thought experiment on turning the engine with an outside source, at the same rpm the engine would be spinning using combustion, is exactly what I was proposing. The turbo would spin at the same rate, whether that air is hot coming from the engine using combustion or cold coming from the engine being spun by an outside force.
Essentially, what happens on the intake side of the turbo is the exact opposite of what is happening on the exhaust side. Yes, there is a change in temperature in both cases but that change in temperature is driven by the change in pressure. That temperature change is also relatively small, not the kind of change needed to do any real work.
Since we are starting to annoy the community with what I would think is an educational conversation, we can take this offline or open a new thread.
