- First Name
- Eric
- Joined
- Mar 19, 2022
- Threads
- 10
- Messages
- 2,166
- Reaction score
- 3,157
- Location
- Belleville, IL
- Vehicle(s)
- '08 BMW R1200 GS Adv, '23 Norden Expedition
- Thread starter
- #121
The issue is we don't know what the scrub radius is and your graphics only show what we already know, that a spacer will move the tire/contact patch out. Those graphics also show that you can get wider wheels/tires that keep the center of the contact patch in the same position while moving the outside of the tire out, which would maintain the scrub radius as you have proposed. Overall, neither of us has info specific to the BS.I gave you visual aids with actual dimensions, not a wikipedia page with arbitrary and non BS specific specs. Believe what you choose but Ford engineers designed the bronco sport to handle and react with a specific scrub radius, my suggestion is to maintain it and put less stress on the already cheap made in china wheel bearings but do what ever floats your boat.
Edit: I'm not sure you understand the purpose of scrub radius especially for braking. In emergency braking, if one front tire has more traction than the other, a very positive scrub radius could produce a significant yaw meaning the your bronco sport will not brake in a straight line.
You clearly fall into the camp of leaving what the engineers did exactly as they did it. That is okay and we are all free to do what we want with our vehicles. Engineers also have to design with the knowledge that consumers are going to change things. I'm not saying that they designed for accommodating an extra 1" of offset but I'm sure they designed in for some.
As I said, I'm sure that by adding the wheel spacer we are changing the scrub radius from a something small either positive or negative to something more positive without being a "large positive", given the reference of 4" being large.
