Things have gone from bad to worse on my flat out installation gr40. After installing from Felix performance trying to adjust the rear heights they’re set initially set at 33.5 and need to increase to 34.5. My second mechanic is unable to do so. There is also massive metal to metal contact on my front suspension . Those front were moved to 34.5 and still have metal to metal co tact. Not sure what the issue with the contact on the front everything seems tight. The front coil overs move the rear do not. It is very difficult to move the coil overs in the rear gr40. I have had no luck contacting flat out only through intermittent email. Hoping someone in the forum can ask flat out to contact me. I probably need a refund for the order because my car is in un drivable now. This suspension is definitely not for a newbie , have to know what you’re doing. But even the experienced mechanic can’t seem to figure out these coil overs.
