All-Weather Floor Mats Question And Possible Flooring Issue
BroncoS56
Midwest
So Ford has two sets of rubber mats for the 3 cylinder trims? One with button hole and one without? Thats what it sounds like?
Apparently. Or possibly three, depending on if you have carpet flooring or rubber flooring. And if you go the the ford website they only offer the floor liners for the rubber flooring not the carpet flooring. It would be nice if they made this a little clearer.
IdahoDirtFarmer
Shane
Caldwell, ID
Ram 1500 ordered '23 sport
My '23 Big Bend I picked up yesterday doesn't have a snap on the passenger side. I put tuxmats in within 10 minutes of getting home and I don't think they can move around so it's no big deal for me. Tuxmats still came with the hole on that side for a snap if needed though.
BodieBronco
Houston
Bronco Sport 2023
I got my rubberized floor mats in!! Hooray!! These are OEM for the carpet so they have little pointed grabbers on the bottom so they don't slide.
back seat: Two pieces in the back. the driver's side is longer to have the bronco over the hump. the passenger side laps over the edge just a bit to hold that down. I love it. Perfect fit and love the look.
The driver's side : has the two snaps. Fits wonderfully. I'm so excited I won't be getting my carpet mats dirty with mud etc anymore. It does not go all the way up under the gas pedal, but the carpet mat didn't either, and i don't see that's needed up there really. I am fine with that, no complaints.
The passenger side: has no snap, neither does the floor. It isn't flush with the floor in the vet back, but that might change as it relaxes over time.
I'm really pleased with the mats
Ford Bronco Sport All-Weather Floor Mats Question And Possible Flooring Issue 20230204_100519
Ford Bronco Sport All-Weather Floor Mats Question And Possible Flooring Issue 20230204_100533
Ford Bronco Sport All-Weather Floor Mats Question And Possible Flooring Issue 20230204_112854
steve bronco
indianapolis
sportrack
The passenger side: has no snap, neither does the floor. However, I'm not thrilled with the passenger mat. It's not that it doesn't fit, but it's not that it does either. All the other 3 fit like a glove. The passenger side feels like it isn't molded to the shape of the floor. There feels to be extra space. The wall of the mat on the side of the door is slightly too high or something, and the mat doesn't fit flush. You can see in the picture how it gaps and doesn't fit along the floor like the others. It pulls away slightly more when the mat is pressed on (as having feet on it would do, since it doesn't fit all the way flat against the floor) it will work fine. But it's odd that since the other 3 are so perfect, that this one almost feels like they really made it for another car and figured it wasn't worth it to really make one to fit.
Overall I'm pleased with the mats
the mat on passenger side looks like it needs to be rotated. the bronco sport logo should be by the door.
Tigger
Tigger
Illinois
It does need rotated 90degrees. The bronco wording should be vertical like it is on the drivers side.
Driver side, passenger side (and filthy from yesterday)
Ford Bronco Sport All-Weather Floor Mats Question And Possible Flooring Issue 968027CC-5832-4DC8-AE33-197ECC80340B
Ford Bronco Sport All-Weather Floor Mats Question And Possible Flooring Issue 817E3ED1-F121-4F9A-859F-6F33B4E89777
BodieBronco
Houston
Bronco Sport 2023
*headslap*
Obviously I was so excited I did this before coffee
Thank you!!!
I'm going to try to edit my original post instead of making a new one
BodieBronco
Houston
Bronco Sport 2023
Thanks!! I did it super fast before putting the dog out and missed that I put it in sideways in my rush. I've updated my review
BodieBronco
Houston
Bronco Sport 2023
Are you happy with your pedal covers? I feel I'm not having problems with my foot slipping off the pedals, but the bronco labeling is fun.
Tigger
Tigger
Illinois
Yes, I like them a lot. I had blue ones on my OBX. They are minorly functional but mostly to look cool. Oddly I get comments on them often. Highly recommend for cheap, easy mod
Suzysparks
Stacy
Acura MDX Type S
Okay… I’m going to be buying the all weather mats/floor liners (whatever you want to call them). Are there two different versions/part numbers? I’m assuming my ‘23 also doesn’t have the passenger side snaps, but haven’t seen it in person yet to verify. I was going to purchase using my Ford pass points. Mine as well use them on something I was going to already buy.
Tigger
Tigger
Illinois
Yes. One is for carpet floors and one is for a rubber floor. Also, for 2023, on the passenger side some have a snap and some do not. My recommendation is that you call the dealership that has the vehicle, have them look at your Sport, and tell them to order the right mats. Also, make sure they take off at least 15%, the current discount on all OEM parts.
They are definitely one of the best accessories if you live in snow and slush country.
The shape is slight different between the ones for the carpeted floor and the ones for the rubber floor.
BroncoS56
Midwest
I agree with Tigger, check your vehicle, call your dealership and give them your VIN, they should be able to order the correct part. That's what I did, after explaining to them that I didn't have the snaps or anchors for the passenger side. The only one that Ford is selling on their website is for the rubber flooring not the carpet flooring, so if you have carpet flooring you don't want that. The one that fit for me was Part No: MP1Z7813300AB, which is for the carpet flooring and without the snaps or anchors for the passenger side. I hope this helps!
tRex
Rochester, NY
Hello everyone! I recently purchased a 2023 Bronco Sport Big Bend. It comes with the carpet flooring and carpet mats. No issue there. But I want to purchase the rubber floor liners. The ones they sell on the ford website are for the rubbering flooring (Part No: MP1Z7813300BA) so I look around and call the parts department at the dealer. He says I need the one for the carpet flooring (Part No: MP1Z7813300AB). Strange that on the ford website they don't offer it but he can order them for me. So I agree and he's going to order for me. However, I noticed while looking at the floor liners (images, videos) that they have these buttons that snap down on these nipples in the floor. Well, I look at my car and I see I have two nipples for my driver's side and no nipple for my passenger side. I asked the dealership if this was some manufacturing mistake but they weren't sure. Does anyone else have this where there is no nipple for the mats to snap in on the passenger side? Is it a manufacturing mistake? Can this be fixed? I would appreciate any feedback. Thanks!
Ford Bronco Sport All-Weather Floor Mats Question And Possible Flooring Issue floor liners
2+1 snaps in my '21 BL/BL w/rubber flooring and rubber mats (+carpet mats in storage). Yes, these rubber mats are different -- I believe smooth underneath for rubber floors, grips for carpet. I wouldn't have been surprised at no snap on the passenger side with carpet flooring, though...?
Mrouse53
Mary
Angleton tx
Ranger
I'll look today, not sure now that I think of it. I ended up ordering Weather Tech, fit really well. The driver side snaps worked perfect on OBX! I'll check passenger this evening!
