- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,727
- Reaction score
- 13,167
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
TNSTAAFL. The only way to significantly increase air flow is to decrease filtration efficiency. K&N filters allow more/larger particles to get to the engine. Enough to affect reliability or durability? That's an unknown. I can tell you that the compressor turbine spins +100k RPM under boost, so everything that impacta it will cause wear.That’s weird I’ve never had an issue. I have one on my 19 ram 1500 and every time filter is due for cleaning I never see any kind of dust inside the intake and I live in the desert.
Given the lack of data regarding real-world performance improvement for this particular engine, I'm not taking the risk to find out. If someone does before & after Dyno testing showing an actual performance improvement I might change my mind.
This is not an issue on race engines that only must last the duration of the race, which is why they use these types of filters. It probably won't be an issue on your engines either assuming you don't plan to keep the car until the wheels fall off. But I don't like words like probably when it comes to reliability of my engine.
