ErikaFrzn
Erika
‘22 Bronco Sport, '15 Explorer, ‘22 Trail Boss
AndyMac204
Andy
Not so much TO my Bronco Sport as FOR it. Wrapped my garage rack in pool noodles to protect the lift gate.
Ford Bronco Sport What did you do TO your Bronco Sport today? 12766111-B0B3-46DE-990C-4592DBCED149
awesome, i do the exact same thing in our carport. cheap and effective.
Virgo Life
USCGRescue
Ford Bronco Spot Badlands 2022
Now that forum members are getting some Bronco Sports to own and love, I thought it would be cool to begin a thread that is often found on other enthusiast boards.
Got your hands a bit dirty working on your Little Bronco recently? Dressed it up? Did a detail? Or how about a mod? Give us a quick post, show us some pics. Share what you are doing to make your Sport uniquely yours.
I’ll kick off with a few items myself to get things started and hopefully we can keep the thread going.
I searched for Mug Guards and Splash Guards after market and found the Weathertech ones to be the best fitting and molded custom to the B.Sport the set of four with the secure pins and clips was $99 freeshipping.
Only issue I hear some mention is if you do stress the tires over rocks at certain angles they may hit and break as they are not rubber but rather Thick Molded plastic.
Took about 20min total to put, on with no drilling.
Here's a vid I made of all steps and results.
Happy Holidays crew !!!
TxHill
Todd
Katy, Tx
Painted the engine cover I bought for my '23 Outer Banks. Now if Ford would just build and ship it to my dealer, I could install it.
Did you order the cover from Ford Parts? Do you have the link?
MHUNTOON
NC
Installed Ford window deflectors last week after driving from NC to IN and my wife complaining about wind noise. It had bothered me a bit as well, but after she brought it up it's all I hear.
The deflectors did nothing to cut back on the wind noise. I'm disappointed, but they look nice and will be nice to have if I want the windows cracked a bit during rain or when parking in a hot environment.
Also noticed that the drivers side fog light doesn't work. Honestly not sure if it ever did and I'm just noticing it now. I've got the light warranty, so when I bring it in I'll see if there's anything they can do about the wind noise as well.
Mrmike
Syracuse, New York 13219
I bought this cover from the dealer where my OBX is on order. It cost me $77.43. The only thing in the box was the cover. I ordered the mounting studs on Amazon. If you research on this forum, you will find several threads about the cover. One of them has the stock # I used and the stud information for Amazon. At one time there was a member on here who was selling a cover. Search for engine cover, and you will get several threads, and all the info you need.
jazzdab
Thom
Raleigh, NC
My experience with window deflectors is that they increase wind noise. Even my low profile EGR visors add some noise. The further they stick out, the more noise.
MHUNTOON
NC
I think you may be correct ... the description specifically mentioned reducing wind noise, that's why I got them
MHUNTOON
NC
I believe they are meant to reduce noise if the window is open.
i generally don't drive with my windows open. if anything the noise is worse. they will be helpful when parked in a hot environment, I'm sure, which will be good. They also look nice.
Kraken23
Allen
St. Louis, Missouri
2022 BS BL
Is there a specific paint and/or application method you used?
Mrmike
I used Artistro multi-surface paint pens. I bought them on Amazon. They worked out well because of the extra-fine tip. You could probably use most any kind of paint, but you need a very small brush.
