Status
Not open for further replies.
LV2ROAM
Phil
Idaho
Folks, just received and installed the Rival skid plat on my BS OB. It turned out awesome. I did run into a couple of small issues when installing but nothing that a DIY'r can't over come. Rival has done a great job insuring that no customization needs to be done in order to make the part fit a non-BL sport. Follow the accompanying guide and you shouldn't have an issue with the install. My total install time was about 30 minutes start to finish.
Ford Bronco Sport New RIVAL Aluminum Skid Plate For Bronco Sport image6
I oiled that screws and pre-set them to remove any burning. Not much noted.
Ford Bronco Sport New RIVAL Aluminum Skid Plate For Bronco Sport image4
OEM plastic cover to remove.
Ford Bronco Sport New RIVAL Aluminum Skid Plate For Bronco Sport image2
Ford Bronco Sport New RIVAL Aluminum Skid Plate For Bronco Sport image1
Insert wing tabs where indicated in guide.
Ford Bronco Sport New RIVAL Aluminum Skid Plate For Bronco Sport image0
And, install..., way better!!
RiotfunK
Mass
22 Bronco Badlands
Be careful if you get oil changes done at dealer since they don’t know how to put bolts or washers back in the right spots. Make sure you look over it after any dealer work. I’ve had to fix mine twice after work was done.
LV2ROAM
Phil
Idaho
Good to know, I saved all my OEM parts and panel so either I'll put them back on or just remove the plate myself and take it in that way.
Blue oval fan
Nick
Greenville, SC
22 Bronco Sport
At that point your more then half way there if you take the skid off. Another 20min you can do an oil change!
mikldom
Outer Banks NC
Just ordered with ShopPay and the discount code. Thanks for posting the code!
Fossil
Ernie
ohio
Would be great to see aftermarket address the Mavericks low hanging picnic table lower front valance- The Tremor's bumper is a step in the right direction but supposedly wont fit a Non/Tremor model -
True on the Tremor, some internals were relocated to allow the BS style bumper. As no one has hands on yet so we'll be wait and see for a few weeks. I've got one on order but it will be awhile.
Ford Bronco Sport New RIVAL Aluminum Skid Plate For Bronco Sport cov
Jocker
Trent
Redmond, WA
2023 Ford Bronco Sport
Now In Stock!
Made from deep stamped 1/4-inch thick aluminum alloy.
Weight: 26 lbs.
Non-corrosive solution with No-drill installation.
Oil change port for your convenience.
Ford Bronco Sport New RIVAL Aluminum Skid Plate For Bronco Sport 2333.1883.1.6_Bronco Sport_1.JPG
Ford Bronco Sport New RIVAL Aluminum Skid Plate For Bronco Sport 2333.1883.1.6_Bronco Sport_2
Ford Bronco Sport New RIVAL Aluminum Skid Plate For Bronco Sport 2333.1883.1.6_Bronco Sport_3.JPG
OIL CHANGE PORT!!!! Thats awesome!!! I was so anxious to get the rally innovations one when they released. But after seeing this.... I might have to do a swap. Plus this one looks way beefier :)
Blue oval fan
Nick
Greenville, SC
22 Bronco Sport
Don't get too excited you still have to remove the skid to get to the oil filter. Rival should just save the money and make the skid solid without that access panel.
RIVAL 4x4
RIVAL 4x4
Diamond Sponsor
Houston, TX
rival4x4usa.com
It’s good that oil change is just not an every day routine ?.
Status
