Looks like either of the Ram standard bases will work fine mounting to that trim piece. I like the look of the Diamond shape better than the round one. I’ll look to see how easy it is run the wire up. I have the traffic module on my wire so I’ll still plug it into the 12v cigarette lighter outlet.
Yeah, mine uses the same traffic receiver cable. If you're brave, you could cut off the 12v plug and just wire it to 12v. But since the darn cable is so pricey and hard to come by, I think it is better to just keep it intact. I don't want to dedicate my existing 12v plug to it. What I did in my last ride, I added a 12v plug under the console. The Garmin cable went through the dash and plugged in out of sight. You can buy sockets or an "extension cord" for a 12v and cut that, leaving a wired female outlet.
If I am going to make use of that area for mounts, I am going to double up because it's past time to invest in a dash cam for this world. At that point I may as well add USB outlets up there too, heh.
Good idea regarding the extension. I forgot that I have one from my motorcycle. I used my Garmin cable from that.
Elegance
Kris
TravisPNW
Travis
Des Moines, Washington
I dropped her off this morning for paint correction... full frontal PPF including ABCD pillars and roof crown... plus ceramic coating along with tinting the front windows to match the rest of the vehicle and throwing in a windshield strip.
She has 400 miles on her and hasn't seen anything but local street traffic... no interstate travel as of yet. The perks of a 5 mile local commute.
The once over didn't reveal any rock chips so hopefully they won't find any... but I have touch up paint just in case.
Pickup ETA Friday afternoon.
Will post before/after pics.
SKBanister
Manteca, CA
2021 bronco sport
what size are your rims?
I'm glad discount tire was able to get back to you. I was at work and would of had to look up the size. I've got over 30,000 miles on those tires and they still look awesome.
MeTheGuy
Nathan
Today I added the AVS front deflector and lo-pro window guards. Thank you Ford Pass Rewards! The roof rack was a week ago and the roof crossbars a week before that. Added rear bumper guard, rear cargo net, Bronco steering wheel cover, and Bronco console cover. Also tray behind info screen and assortment tray in console.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_20221104_152554375_HDR
Kraken23
Allen
St. Louis, Missouri
2022 BS BL
Well I’m sure someone will say “could have told you that” but for any others that are wondering do not buy one of the Bronco emblems off Amazon. I did and after installing it I noticed that it was starting to separate from the adhesive, not at the car but at the emblem itself. Well I made the decision to buy the official Ford one and take this one off the car. I’m glad I did because once I did it came off the adhesive real easy and that’s when I noticed it was basically hollow inside and was really only attached to the adhesive around the edges. Of course the adhesive itself was stuck to the BS like nobodies business and it took me about 45 minutes using slight heat and my nails ending up with Goo Gone to get the last bit of adhesive off the paint. I am hopeful that the official one will work better. You live and learn as they say.
