OEM Crossbars too high?
Jmuns
2022 Bronco Sport BL
My wife and I are planning a cross country road trip. I have a Thule Canyon XT basket that I’m going to use. The OEM bars are fine with the basket close by. I haven’t had it loaded for long trips. Does anyone feel that the OEM crossbars are just too tall for platforms/racks/baskets? I’m not concerned about the MPG and drag, but to me it just looks like that weight sitting up an additional couple inches versus using some lower mounted crossbars (Thule or Yakima) could affect the roll and pitch of the BS. Anyone have any thoughts? Or anyone load up a basket or platform with the OEM crossbars and travel extended distances?
I think the stock cross bars are as tall as they are because of the sunroof option. It seems to be a close fit with a lot of aftermarket cross bars with a basket.
Jmuns
Jmuns
Yea that’s most likely the reason. I like the way they look, but they aren’t the most functional. I just can’t decide if I want to spend money on some Thule crossbars to lower it a couple inches and also gain some additional room for an awning. I’ll most likely just keep using a tarp anyway as opposed to buying an awning. Accessories are just a rabbit hole once you start adding them on.
Mexray
Ray
Nor cali
89 Bronco, 22 Badlands Bronco Sport on order
sajohnson
Sherman
MIDDLETOWN, MD
A couple inches lower would make very little difference.
What would help more would be lowering the amount of weight as much as possible.
My roof box has aluminum conduit bolted to it. Four U-bolts attach it to the rails. It knocked my gas mileage down by about 4mpg at freeway speeds. I put the light weight bulky stuff on the roof, like foam pads, lawn chairs, aluminum table. If you're worried about roll-over, you're driving like a teenage, or taking trails a lot rougher than I do.
Jmuns
Jmuns
Thank you for the response. I’m just overthinking it some.
