jimharrison1950
Buckeye, AZ
2022 Bronco Sport Big Bend HOT PEPPER RED
Mileage and noise are two areas with not enough discussion, IMHO. We'd all like tires that have better traction and are more capable ... but at what cost? For those with frequent off-road needs it is likely worth it. For the rest of us, what is the best compromise? I want something that will work in rain and light snow conditions, not get me stuck in mud while still being fairly quiet with minimum impact to mileage. Up until recently, I had been eyeing Yokohama Geolandar A/T G015s as a future replacement. Right now I am liking what I read about Continental CrossContact LX25s. Seems like a more measured approach but still an upgrade from stock.
Installed Ford-Alexa on our 2022 BS BB and works awesome!
NEFKANO
NEFTALI
El Paso, Texas
neftalicano.com
Yet another successful venture out with the Sport...You can't tell by looking at this shoreline, but I had to navigate loose small boulders and yes took a few strikes against the underarmor, lol.
Besides the Badlands included rock plates and my addition of the lighter Rally Innovations front skid plate... I'm hoping someone will create a side plate for those lines running underneath the driver side. Right now its a thin piece of felt covering those hoses... but hoping someone can manufacture a long plate for that section... I believe its the fuel lines.
But all In all a successful venture trough narrow roads and loose loose boulders and rock.. performed like a champ.
Baby Bronco Power at it's best : )
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_7212
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_7219
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_7193
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_7197
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_7201
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_7217
Reactions: Jrl
jazzdab
Thom
Raleigh, NC
Got in there with some Griot's Garage Heavy Duty Wheel Cleaner. Did not realize how utterly filthy my front wheels were - basically matte grey. The replacement pads from the recall are just a disaster. I need to go ceramic.
Ford Bronco Sport What did you do TO your Bronco Sport today? wheel_dirty
Ford Bronco Sport What did you do TO your Bronco Sport today? wheel_in_process
cgreen5150
Chris
Lincoln, CA
I'm with you on that one. I still can't believe that Ford thought that thin piece of felt was enough to protect the gas lines in a vehicle that was designed to go off-road.
Seebs
Fred
Charlestown, RI
2022 Bronco Sport Badland/2013 Mustang Convertible
Wednesday will be the 1 year anniversary of the purchase our Badlands and 15000 trouble-free miles. I installed the spoiler (Thanks to pass points) rear window decal and pedal covers.
Ford Bronco Sport What did you do TO your Bronco Sport today? DSCN7446
Ford Bronco Sport What did you do TO your Bronco Sport today? DSCN7445
Ford Bronco Sport What did you do TO your Bronco Sport today? DSCN7444
Ford Bronco Sport What did you do TO your Bronco Sport today? DSCN7443
Nice work! I love my Badlands, too (13K/6 mis.). Where did you purchase those pedal covers? Thanks!
Tigger
Tigger
Illinois
I like your additions and I have an Area 51 too. I am curious why you went with red instead of the blue?
Seebs, here’s the link on Amazon
https://a.co/d/hbVUMsV
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
follow up to yesterdays post
checked stud used for grounding harness controller
Battery 12.59 volts
Battery through voltmeter to grounding stud 12.59 volts ✅
ran controller positive wire internally
through lamp housing (empty existing plug) to cargo area
up rear hatch post
across ceiling liner using conduit fish tape
down "A" pillar to fuse box
If anyone has a recommended fuse spot I'm all ears
https://fuse-box.info/ford/ford-bronco-sport-2021-fuses
so far the (spare) no.15 no.16 slot seems okay????
Ford Bronco Sport What did you do TO your Bronco Sport today? 1662321304520
Ford Bronco Sport What did you do TO your Bronco Sport today? 1662321390179
Ford Bronco Sport What did you do TO your Bronco Sport today? 1662321453240
[/QUOTE]
ready to install fuse tap
should be a snap
aaaaaahhhh
micro3
when did this happen
micro3????
on standby
I'm a friggin dinosaur trying to live in a timeline where I don't fit in
NEFKANO
NEFTALI
El Paso, Texas
neftalicano.com
Well between computer chips and that mythical foam engine cover… a protective plate covering gas and brake lines was probably considered a luxury item ona n off-road vehicle…lol
