- First Name
- Cristian
- Joined
- Jun 6, 2022
- Threads
- 0
- Messages
- 7
- Reaction score
- 20
- Location
- Washington
- Vehicle(s)
- Bronco Sport
I really like the side lights, but I hooked them up to the DRL Lights.
It's a paint to do it with the tire on but it's doableRealizing that @Wabarca2 ran the red wires to the courtesy side markers, not to the headlights - that’s probably where my issue lies. No idea if there’s a headlight wire that stays on with the DRLs, worried I’m gonna have to run those red lights down behind the wheel wells.
did you just pop the plastic rivets out, pull back the fabric, attach the wire, then push everything back and reattach the rivets?It's a paint to do it with the tire on but it's doable
That's exactly what I diddid you just pop the plastic rivets out, pull back the fabric, attach the wire, then push everything back and reattach the rivets?
were the rivets a pain to pull out and push back in? Any concern about damaging them?That's exactly what I did
I have the plastic panel removal tool from harbor freight and it made I easy, you want to do the round middle part first then the basewere the rivets a pain to pull out and push back in? Any concern about damaging them?
thinking I can take a crack at this tomorrow morning on the driver side to see if I can get it working.
ok cool I have that same set from them, I’ll take a crack in the morning and see how it goes. Appreciate the help.I have the plastic panel removal tool from harbor freight and it made I easy, you want to do the round middle part first then the base
You got this, if you have any other questions I'm here to helpok cool I have that same set from them, I’ll take a crack in the morning and see how it goes. Appreciate the help.
The original set up doesn't have lights it's just plasticI have such a dumb question, but what does the stock set up do or look like?
In all the night photos of the BS, I've never seen that area lit up.
Ok this is how my mechanic hooked them up. Left headlight wiring harness. Red wire goes to the white wire. Yellow wire goes to blue wire with green stripe. black wire goes to black with green stripe. Good luckWell got them installed - and of course, the left driver's one doesn’t blink amber, but instead the white lights blink (daytime running works fine). Thinking there’s a wiring issue somewhere inside the light itself and that’s why it’s doing that.
Either way, attaching some photos of the install to see if maybe I'm just an idiot and doing something totally wrong here:
just tried this as a quick fix - running into the same funkiness as before, the white lights light up fine, but the amber never turns on (even with turn signal or hazards). The white lights blink on those latter two, but it never kicks over to the amber.Ok this is how my mechanic hooked them up. Left headlight wiring harness. Red wire goes to the white wire. Yellow wire goes to blue wire with green stripe. black wire goes to black with green stripe. Good luck
tried a second set of lights I had ordered to see if it was the light vs wiring, but same thing happens - white turns on and blinks, amber never turns on.just tried this as a quick fix - running into the same funkiness as before, the white lights light up fine, but the amber never turns on (even with turn signal or hazards). The white lights blink on those latter two, but it never kicks over to the amber.
