dakman
I've put over 6k miles on the BS since this install and have had no problems with any 360+ features. Adaptive cruze works great and I use it every day. I also had a new windshield recently installed and there were no problems calibrating it being lifted and the lightbar on.
CrazyKZ
Ken
Allen, TX
That’s good to hear. Everyone else, and even the manufacturer, says it will interfere with the adaptive cruise.
dakman
I don't know exactly where that sensor in the grille is, the bar sits just a little higher than the bumper opening but it works great. I did hang my lights down but don't think they would have interfered.
Ford Bronco Sport What did you do TO your Bronco Sport today? litbar1
Elegance
Kris
Wash and wax with my new suite of Chemical Guys products (including my new foam cannon)! The Bronco looks like I just drove it off the lot. Whoever buys this when my Badlands comes in, I hope you appreciate my elbow grease.
Did it during the witching hour because Arizona, but I can hardly wait to see it in the sunlight.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20220731_200942
WLK
Wendy
Looks so much better with the black on the lettering.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG-9221
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG-9222
MHUNTOON
NC
Attempted to install the mud flaps from our sponsor @Rofitds. Box arrived in a timely manner and in good condition, but no instructions. Was thinking of buying a couple of other things from them, but I’ll hold off for now.
No reviews yet, so I added the following to forewarn others. I’ll happily edit it if it’s easy to figure out. Included a picture as well.
Getting ready to install and figured I’d get everything set before I head down to the vehicle. No instructions, just the flaps and the pictured baggie of screws, washers, and clips. Do I need a washer and a clip? Just one? First impression- not great. Flaps seem sturdy, so we’ll see. I’ll either be requesting a refund or editing the review once I go down and try to figure it out.
Seller - the picture you include in the gallery does not count as instructions. Heading that out there ahead of a feeble excuse.
I’ll let you all know.
Still no reply from our sponsor @Rofitds and I haven't had time to go out and play around to figure it out on my own. Hopefully, I'll have time tomorrow. As of now, can't recommend this seller. Was considering their body side moldings, but that's obviously not happening at this point.
Installed a console safe. This was the easiest of all the mods I've installed so far. It's just a locking lid in a frame with two side plates that slide down into the console. It's held in place with four screws that go through threaded holes in the side plates. You simply drop the assembly into the console, then turn the screws with a 7/16" socket on a ratchet until they bottom out. The self-tapping screws will bore their way into the plastic sides of the console. From the looks of it, the only way to get into the console with this installed is with a crowbar.
Because the only thing inside the console is the two side plates, you do not give up access to the charging ports. You will lose a small portion of the console's internal volume, and reduce the size of the largest item that will fit through the door. In the first photo below you can see the assembly inserted with the screws in place. There's room for all the stuff I usually store in the console with room left over to fit a medium-sized belt bag.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20220801_170624_2
Ford Bronco Sport What did you do TO your Bronco Sport today? 20220801_171244
Bluebaru
My Brother and I headed out to Bear Creek Lake state park and the surrounding Willis River area and did some lite trail riding (well graded gravel roads) and passed both a Revolutionary war memorial and a Confederate grave yard. Put about 150 miles on it and now have 500. Our favorite burger place (True Fixings) was closed, forgot it is closed Tuesdays, so we went to the local Italian place and got a HUGE bowl of baked spaghetti.
MNBroncoLady
Jennifer
Minnesota
www.flyingorangewebdesign.com
Thanks for sharing! Was curious on how would looks. Definitely going to do the black lettering but going to coat them fully.
Looks great for you but my vision is going all black with none of the existing showing. Can’t wait for my Sport to get here.
Reactions: WLK
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
"passed both a Revolutionary war memorial and a Confederate grave yard"
took Sparkplug out for a ride a few days back
house shopping
going remote
easy to spot the old time homesteads
gianormous oak tree someplace on the lot
bonus to spot a family burial plot not too far off
"Memento mori" my friends
"HUGE bowl of baked spaghetti"
Pavlov experiment got me
Rogerthat898
Roger
That's beautiful. Would you share the svg file?
You can use and free svg converter on google and it will do it for you. Or in the Cricut app it will do it for you also.
Make the Bronco Script .75" in height and the length will change automatically.
Each stipe is .25" in height.
The lengths of each stripe from the front of the BS going back are...
7"
23.5"
17"
Ford Bronco Sport What did you do TO your Bronco Sport today? broncoscript
brianloch1974
Brian
Butler, PA-USA
2022 Bronco Sport Big Bend
7"
23.5"
17"
Thank you
