Bronco Nation Grille Badge Mounting
Cactusjk
Jeff
Scottsdale, AZ
Has anyone mounted a BN grille badge on their Badlands? Looking for placement options.
RS1
Ralph
Boston
Can you show us what it looks like, front and back, and maybe ideas will start flowing.
I guess having it sit off to the right affects my centering impulse. So...up to you? Really don't want to block the grill, centered or off center I suppose?
dakman
not sure whats its made of or how it attaches but I think that would look good on the back, rear window or hatch somewhere.
It won’t block enough to count. The louvers will compensate if something causes a difference.
You could put four badges along there and make no difference. It becomes the thermostats problem and it can handle that small amount of change in air volume.
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
Ford Bronco Sport Bronco Nation Grille Badge Mounting 1657590649774
Here is an example.
more interested in the exterior routing of roof wiring
very nice approach
eliminates roof penetration
eliminates excessive interior dismantle/re-install
has benefit of temporary use if needed to remove
Question CactusJk?
Did you post this on a previous thread that I missed?
Ford Bronco Sport Bronco Nation Grille Badge Mounting 1657636005602
very nice approach
Question CactusJk?
The top right where you have the wires crossed,that cap is removable to run wire down the A pillar , on the inside.
Ford Bronco Sport Bronco Nation Grille Badge Mounting F916B801-F7EB-46D5-855D-0EDB6AC0EECB
Major Kong
Major
Kind suspected that was the case
but why the big deal on interior dismantle per Ford
"A" pillar route simplifies everything
Reactions: Jrl
Did you find the instructions, do a search on a pillar light bar .
Ford Bronco Sport Bronco Nation Grille Badge Mounting 4DEB0137-292F-42FD-82D2-90B2B7152740
Ford Bronco Sport Bronco Nation Grille Badge Mounting 5630AD2A-602E-4FFD-9C30-6169B219D10D
Major Kong
Major
yep, that's it
https://performanceparts.ford.com/download/instructionsheets/IS_M-15200K-CXR.PDF
just all the steps prior to figure 34 seems a tad overkill
did manage to find the exterior run wire info
"I used the KC Wire Hiding Kit. It runs right along the A-Pillar and it disappears when the beveled edge is put against the window frame. No drilling and no forcing the window gasket or molding."
if I muster up the courage to pull interior trim that's preferred
option no.2 KC wire hide
Nosmo Rex
Beaverton, OR
2023 Bronco Sport Outer Banks
Just mounted this on my OBX:
Ford Bronco Sport Bronco Nation Grille Badge Mounting IMG_20230710_173841
How'd you get one?
