Found it. 29.5
225/65/17 => 28.5" no rub
235/65/17 => 29" no rub
245/65/17 => 29.5" no rub
235/70/17 => 30" probably rub at worst case (compression & steering)
245/70/17 => 30.5" definitely rub at worst case (compression & steering)
RiotfunK
Mass
22 Bronco Badlands
I went down from the 245/70 to 245/65 because too much rub on pinch seam, etc when on full lock or wheeling. Fit better before lift, but still rubbed. The lifts bring the wheel in a lil toward the strut tower since there isn’t an UCA. If I did it again, I would do the 245/65/17 and leave the BS BL without the HRG spacer kit.
I went down from the 245/70 to 245/65 because too much rub on pinch seam, etc when on full lock or wheeling. Fit better before lift, but still rubbed. The lifts bring the wheel in a lil toward the strut tower since there isn’t an UCA. If I did it again, I would do the 265/70/17 and leave the BS BL without the HRG spacer kit.
So what is the outside overall of that size ? You think that would fit a first edition badlands ?
Ford Bronco Sport 2022 Badlands lifted on 1.25” HRG Lift and BFG Ko2 81820D89-0AA0-47B9-B178-C58608CED0D3
31.6” diameter
No way in H*LL that would fit without rubbing. I’m guessing that was a typo.
31.6” diameter
Yes for sure would rub . I am going to stick with 245/65/17 wild pecks on my next set .
Sean
New Jersey
2022 Bronco Sport Badlands, 2016 Subaru Impreza Sp
Hey all , just joined up and thought I would give you a quick rundown of the BS as it stands today.
I’m debating taking the rear spacer lift off to level the BS I was able to keep the front factory tow-hooks and paint them.
the tires do not rub but there are close at full lock.
2022 badlands
1.25” HRG Lift
245/70r17 BFG KO2
Fifteen52 wheels
Rough country nudge bar
Rhino rack pioneer platform
Magnaflow dual exhaust
Ford Bronco Sport 2022 Badlands lifted on 1.25” HRG Lift and BFG Ko2 56A25BB7-04C3-4CD8-B78A-D6D78DAEFCED
That looks amazing. Did you have to install a positive control arm for the rear when you added those tires? Just had an alignment after the same lift and the tech said I would need it for any bigger tires.
Reactions: Jrl
RiotfunK
Mass
22 Bronco Badlands
There’s no aftermarket arms out. Is stock. You need a more positive offset on your wheels than what the oem wheels provide to push the wheels out some since lifting these pulls the wheels inwards.​
Sean
New Jersey
So how did you do it? Did you go without the rear spacers?
Your alignment guy doesn't know what he is talking about. There are probably at least 40 people on this forum that have done a lift and are running 245/65/17 (29.5") tires and don't have a "positive control arm" installed. Your posts are the first I have seen calling out such an item.
Not trying to be gruff, just stating the facts.
Sean
New Jersey
Thanks, appreciate it. I felt like he might be full of shit too.
RiotfunK
Mass
22 Bronco Badlands
You’re not lifting enough to need adjustable arms. Mines HRG lifted same as OP and no issues. But did need the cam bolts. I did go down from 245/70-245/65s cause the rub was to much. If you’re gonna wheel the 65s are a better choice. The rear was fine even on the 70s. The front is where the issues are.
