Boomba Racing Blow Off Valve (BOV) adapter; Vent to Atmosphere on BL 2.0
mrwhitson10
Matt
Johnson City, TN
2021 Bronco Sport Badlands
Hi all. I recently installed this BOV adapter from Boomba racing that allows the turbo to VTA.
I have to say I am very impressed with the part. You get that nice turbo blow off sound and reduce pressure on the turbo when you release the gas pedal. I have also noticed that the turbo lag has improved some.
Here is the link if anyone is interested:https://www.boombaracing.com/ford-ecoboost-blow-off-valve-adapter-bova-v1/
A photo of it installed as well. If I get time I will try to post a video of the sound it makes as you accelerate.
Ford Bronco Sport Boomba Racing Blow Off Valve (BOV) adapter; Vent to Atmosphere on BL 2.0 F5766BDC-9DFD-47EC-9A3F-B669423EDC60
Stitch50
AK
NH
Ford Bronco Sport / Ram 1500
Any idea why it’s not listed for the 1.5?
Huntyeraws
Nick
Rochester, NY
2021 Ford BS BB
Why?
casual_reader
MJ
mississauga
Bronco sport OB / Focus RS
question. now that your had the BOV for a while. Have you noticed any hissing noise during prolong highway/freeway speeds?
I changed out my diverter valve/recirculation valve on my RS with a Boomba unit. And had to get Boost Reference adapter(BRA:giggle:) from Turbosmart afterwards.
ChefDank
Nick
New York
How was the install and location?
mxATVracer10
Derrick
Sapulpa, OK
2021 BS/BL, 2013 Fusion SE, 2004 F-150 FX4
Not OP but I can answer this one... I have had my BOV since black Friday '21 but just installed it last weekend! I had tried to install it previously, but was following the only video I could find at the time, which was on a 2.0 Focus ST. On it, you have to remove the passenger wheel to gain access, however the BS has a plastic shield that I couldn't get around so I gave up. Randomly searched the other day and there is now a video of one being installed on a Maverick, which of course is the same layout.
BOV Install
The install is EXTREMELY EASY! :rockon:
ChefDank
Nick
New York
BOV Install
Yeah I saw this last night.....BOV will be my next mod ?
ChefDank
Nick
New York
I'm not in it for the sound; I'm in it for the functionality of a BOV. It's meant to stop back pressure to the turbo.
I've had turbos in my cars since 2009 and I've had to replace a few along the way.
In my world it's called preventive maintenance. Even when you arrive at your destination (especially after a hard run) I'd suggest letting your vehicle idle to cycle out the hot oil from the turbo. It'll extend the life; believe me.
At the end of the day......to each thier own ?‍♂ you do what you want to your vehicle and I'll do what I want. ??
Dark
Northern VA
agree. This ain’t Fast n Furious :cool:
to each their own
would this void warranty?
depends on the issue. If the bypass valve failed then they likely won’t replace it under warranty.
The engine is equipped with a recirculation valve from the factory that does the same thing. The only difference is it vents back into the unpressurized portion of the intake tract so it's not as noisy.
