- First Name
- Greg
- Joined
- Mar 7, 2022
- Threads
- 1
- Messages
- 52
- Reaction score
- 61
- Location
- Oklahoma City
- Vehicle(s)
- Bronco Sport
Thank you so much!Got them on Tirerack.com and they are going for $319 H&R Springs
Going by the ford website I am 1" inch higher than a stock BL using the combination of the springs and 245/65R17 TiresHow many inches did you gain
That’s the beauty of the springs, their is no grinding, that is one of the reasons I went with the springs.Does H&R recommend trimming metal like the spacer lifts do? I am trying to avoid needing to grind anything…
Measured the advertised 1.2" and a little some.Did you measure the wheel wells before and after? Looks good. Waiting for my Badlands with the tire upgrade!?
Yes, they are badland wheels with 245/65R17 tiresLooks Good - are those Badlands Wheels that you have on there?
I didn't want to grind the struts and wanted to maintain as much of the ride quality as I can wich it did, here is the press release from their website that made me make the final decisionFinally a reasonable lift done right !
I never did like the Idea of spacers. 1.2” plus a tad more to comp for a little spring settling.
I am assuming they have the same spring rate as stock so you can still use all your travel.
The new Ford Bronco Sport has a stylish rugged look ready for your adventure. H&R ride engineers have developed adventure-raising springs for off pavement exploring and overland excursions.
H&R Raising Springs (PN: 51680) have a mild lift of approximately +1.2” front and rear for more ground clearance and a commanding view of the road. Specific spring rates retain ride comfort and control. Blaze fun adventures with H&R Raising Springs, Wunderbar!
Like all of H&R’s products, H&R Sport Springs are 100% made in Germany and use only the finest quality materials and precision manufacturing to maximize service life. H&R springs are pre-set or “blocked” using an exclusive process that ensures the springs will never set or sag, for miles of smiles.
H&R Special Springs is a German-based suspension company that has been built on a foundation of superior quality, true performance and the best customer service. H&R has established a proven heritage of unsurpassed industry respect and customer confidence, all of which gives H&R the definitive edge in suspension tuning and design. All H&R products are crafted in Germany and exceed ISO 9001 quality assurance standards. H&R maintains a U.S. facility located in Bellingham, Washington, where additional testing and research are conducted.
Went to the beach to flex it every possible way and the bottom of the shock never touched the cv axle.I’d say you’d need to grind the bottom of the strut a little regardless of lift since you are still changing the angles. And bringing shaft closer to strut with flex. Plus the spring will give more flex than a spacer and allow more upward travel. Takes two min to do. Not sure why you wouldn’t.
Looks good and I love the rally innovations skid plate; just wish it was a tighter fit around the edges.Went to the beach to flex it every possible way and the bottom of the shock never touched the cv axle.
