Goinbroke2
Nova Scotia, Canada
2021 Bronco sport badlands
But… on to what I did to it….
So far we have tore off two skid plates, ripped out the inner fender, broke the windshield and the latest.. tore apart the “skid plate cover”??
wife bottomed it out while trail riding with her girlfriend, I taped it but that lasted until it hit the highway the first time.
So, pulled the cover off;
Ford Bronco Sport What did you do TO your Bronco Sport today? F7C3A61C-3AD1-4832-82C1-F259D932E26E
Ford Bronco Sport What did you do TO your Bronco Sport today? 7C4F90F3-3384-4B79-A745-3C9D7B085F58
Pulling it off
Ford Bronco Sport What did you do TO your Bronco Sport today? D4AE9D44-1050-4863-8B23-49D201301A87
Ford Bronco Sport What did you do TO your Bronco Sport today? C6BEF2E5-2929-440C-86D0-BD6F8B42835D
Laid it out and made a template
Ford Bronco Sport What did you do TO your Bronco Sport today? 4A1F8052-832F-4E84-AC03-0C0B5B75F7F4
Ford Bronco Sport What did you do TO your Bronco Sport today? 3F6579B7-3882-4A1C-B181-8BCDCF9B742E
Ford Bronco Sport What did you do TO your Bronco Sport today? 6A3E1568-3E58-4B1D-9AE6-C6F72FB96F61
Goinbroke2
Nova Scotia, Canada
Damage….
Ford Bronco Sport What did you do TO your Bronco Sport today? CF17952E-B55D-40E2-BA67-2E74B4183592
broken windshield…
tab to hold inner fender to the outer one snapped off so there’s nothing to put the button into;
Ford Bronco Sport What did you do TO your Bronco Sport today? 621532DC-628D-44AB-9978-C8F7FCCC6D31
The rest of it has been fixed already, but more to come??
Econoline
socal
Do you think any of the aftermarket skid plates like the Rally Innovations would have survived any better?
Goinbroke2
Nova Scotia, Canada
Oh yes for sure. When I say skid plate though, I should clarify, it’s not really skid plates as much as it is an aerodynamic cover over the actual skid plates. I was tempted to leave this cover off completely and make a proper skid plate, but I just fixed this one.
The issue is tearing the …. Ummmm… plastic/felt/whatever it is, (cover ?) or pulling it off over the nuts that hold it in place. The first time, it was hanging down because the nut was pulled off. The next time, it was pulled down over the nut. The last time it was ripped when the wife bottomed out on a rock and slid forward to get off instead of backing off the rock.
So, an actual aluminum or steel skid plate wouldn’t of been damaged, but I’m guessing the cover helps with mpg.
A concern I do have is the ecu being inside the front left fender… not sure what ford was thinking there. Maybe they wanted an “off road looking” truck to replace the escape and never considered people would do what I’m doing?? Awd and goat modes should do 99% of “soft roading” but what happens when someone does take it out in the “holy crap” area’s??
At some point I’m going to go over the underneath and add actual skid plates if/where required as well as look at the front skid plate which I think is a little light.
So, short answer is yes, aftermarket plates would be awesome but you still have to deal with the felt underbody cover and felt inner fenders.(again, felt, held in with plastic push pins, ford, what were you thinking???)
Then used a piece of aluminum (it just looks like an aluminum road sign… nothing to see here, move along..??
Ford Bronco Sport What did you do TO your Bronco Sport today? 75FAB498-D5B2-49F9-A6BC-6876AE8FFEC3
Ford Bronco Sport What did you do TO your Bronco Sport today? 13F702B4-992F-4ECC-BFCD-C581F07F3923
Ford Bronco Sport What did you do TO your Bronco Sport today? 0DA6B342-3DAD-4337-8BC3-C3C54A59AFC5
Now I’ll have to undercoat it to cover the screws!
I wonder if spraying those things with bedliner would be a good preventative move?
spiritedcharm
Scarlett
Ohio
Bronco Sport Badlands
Just added these adornments. I've gone sticker happy!
Ford Bronco Sport What did you do TO your Bronco Sport today? 53CB76E4-9DA0-4393-9E8B-8643B0C55D62
Ford Bronco Sport What did you do TO your Bronco Sport today? 40256113-77AB-4BAA-B14B-30A6F8DAA8DE
Ford Bronco Sport What did you do TO your Bronco Sport today? 42472D28-9512-4727-9F72-6EE8DCF7C132
ScotyA
Scot
MD
Nissan
FWIW When Ford contacted me via email I gave a thorough review of everything from the dealer to the vehicle. I advised them that it seemed petty to omit an engine shroud cover. I also advised the same as omitting seat back protectors and fog lights from the "BB Package" I was able to get my seat back protectors by not the window sticker but the actual build sheet specifications. It was based on production date of the vehicle. The decluttering seemed to change as supply lessened(common sense). I still feel that even on a $31,000 compact SUV minor things like the seat back protector and engine cover should be there. The fog lights I understand but that could be retained also.
I put the flairs on my Sport, really like em!
thekingprawn
Dustin
Kingston, Wa
My wife has started learning. I can't to see what she comes up with when she makes stickers for something other than the cricut.
Ford Bronco Sport What did you do TO your Bronco Sport today? 280147679_575396633850087_1235904503019061642_n
cmc16
Colorado, USA
Finally getting around to posting these after decals were installed. Tinted the front windows to match the back, added the topographic vinyls on the quarter glass, and installed the Yakima roof rails.
getting clear bra done on the front tomorrow since I already have a rock chip and looking for some beefier tires.
Ford Bronco Sport What did you do TO your Bronco Sport today? 1014E70B-155C-4779-A629-D1C7EE39EEA4
Ford Bronco Sport What did you do TO your Bronco Sport today? C0D6B6FC-568D-494D-AE7D-9C47156E6D57
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
Installed nerf bars
Needed to intersect and perforate liner
Used Kydex to fit form cut zone (worked great)
After thought was this
I may run a test on one side just to see how well it performs
Not a skid
But better than plasti-felt
