OEM Mudflaps. Happy with them?
DaveInSA
Dave
San Antonio, Texas
2021 Bronco Badlands
Ya, think it's too late now for me since my BL is already scheduled for production.
The last thing I want to do is change something and be put to the back of the line. ?
They aren't hard to install. You do have to drill a couple holes, but it's really just through plastic and not a big deal. I installed them on mine.
Ford Bronco Sport OEM Mudflaps. Happy with them? 1651428762578
This tire is turned the wrong way for installation because I'd just finished installing the passenger side and hadn't straightened the wheels out before the picture. When doing the drivers, turn the wheels to the left to give you more room, then to the right for the passenger.
Ford Bronco Sport OEM Mudflaps. Happy with them? 1651428782880
Ford Bronco Sport OEM Mudflaps. Happy with them? 1651428790009
The rears, I just got friendly with my back tires.
You can see some of the 45 gallons of tire shine that the dealership put on had already sprayed off the tire on to the vehicle in the 2nd pic :)
retiredguy
It was a straight forward install and they fit perfectly. For around $100, I am happy so far.
The stock cheap ones from Ford seemed to be the way to go. Not hard to install but the backs can be a pita with the tires installed but doable. Well worth it IMO although they are a bit long for driving off road.
Benanza
Ben
NJ
Removed after they got caught off road and broke one
Ford Bronco Sport OEM Mudflaps. Happy with them? PXL_20210730_190158719_2
Ford Bronco Sport OEM Mudflaps. Happy with them? PXL_20210813_135033010
RS1
Ralph
Boston
Mine were listed on the window sticker off the lot. Happy with them. The little flappy things in front of the front tires, not holding up well at all.
Agreed. I think they will need to come off when off-roading. If not, they may be taken off by Mother Nature and she may not be as gentle as you would.
AGLzaca
Pacific NorthWest
NA
Currently installing them. Discovered I'll need a drive socket set to properly put them in, so I'll sort that out tonight hopefully.
Good tips on turning the tires. I'll do that for the front. Though a bit of a pain that you have to drill, even if only through plastic.
The drilling part is painless. The placement of the speed nuts in the rear is a pita. I guess that goes without saying!
Deleted member 6350
Perfectly Happy with them, not a 4 wheelin guy so I’m not inclined to go off road with her, maybe an occasional fire road that’s all. Waiting for it to warm up a bit to do the fronts.
Ford Bronco Sport OEM Mudflaps. Happy with them? 27437A7C-D737-4DC3-8F56-2E4A3E015AD5
Ford Bronco Sport OEM Mudflaps. Happy with them? D4BFE843-9987-4A3D-867B-99E1A5223BA8
Ford Bronco Sport OEM Mudflaps. Happy with them? 069228F1-7BD2-4EDA-ADD9-15004FE23E33
Both of my front factory ones have fallen off. Not sure why, no signs of striking anything either....
Are the holes ripped? Can you snap a picture where it was mounted?
