Active Grille Shutters on BS
dannyc928
Danny
CA
I noticed on a newer 2022 BS window sticker a new addition or feature to the BS. Is it really new? I bought a 2022 OB and it was not on my window sticker. Does anyone else have this active grille shutter? And what is it?
pretty sure this has been there since day 1. The window sticker is not an all inclusive list of what on the vehicle. Its just highlights based on current hot points.
dannyc928
Danny
CA
From what I could find online, "Active Grille Shutters open and close automatically to control airflow, reducing aerodynamic drag and improve fuel efficiency." How can one tell if they have this system on their BS?
Look at the grille. In this case it is the lower grille and you should see “shutters” that can move.
Petroph
Arkansas - United States
2014 FX4 F150
Interesting. Don't think I've ever owned a vehicle with something like this. Does it shut during certain speeds?
o0260o
NJ/NYC
2021-2025 BroncoSport (sold)
I don't know how the ecu figures out when to open or close them. Sometimes when it's raining you'll notice some water get thrown up on to the hood. I think that's from the shutters moving.
I think the logic is tied to engine coolant temp but not 100% sure of that. So, if it is warm and you are in slow traffic they will be open but when on the highway cruising they can close.
It's a drag reduction measure. At highway speed the biggest factor affecting fuel economy is drag created by air resistance. The least amount of drag occurs when the air flows smoothly around the car without any turbulence. Any turbulence created by protuberances increases drag, and the increase is exponential with speed.
The radiator is essentially an air brake; air must be slowed going through it to allow heat transfer from the coolant. At slower speeds air must be forced through the radiator using either a fan or the movement of the car through the air. Forcing air through the radiator via vehicle movement creates drag, which isn't much of a problem at slower speed, but the drag increase is exponential with speed, and at highway speeds can have a significant effect on fuel economy. Some bright boy or girl found, however, at highway speeds there is enough air flowing around inside the engine compartment to facilitate heat transfer without forcing air from the opening in the grill. So closing the grill shutters takes the radiator out of the air flow, thereby reducing overall drag and increase fuel economy.
That's the theory, anyway. How effective they are at improving economy in the real world is a subject of some debate.
Very easy to see, very. And they All have it.
Petroph
2014 FX4 F150
Anyone have a picture of what these look like? Is it the actual grill itself that closes or something behind the grill you can't really see?
thekingprawn
Dustin
Kingston, Wa
Lower grill holes. Open in this picture.
Ford Bronco Sport Active Grille Shutters on BS 1634906048217
thekingprawn
Dustin
Kingston, Wa
His are better pictures.
Deleted member 6350
I took some pics of the “Shutters” you can just about make them out there in black.
Ford Bronco Sport Active Grille Shutters on BS 7BE5A8E0-5F4C-4603-86D5-F2AD295662E8
Ford Bronco Sport Active Grille Shutters on BS 2782E3B8-CE99-443C-B844-97F3040858E5
Ford Bronco Sport Active Grille Shutters on BS 1C151446-F990-4450-8F2D-8417085FB6BA
Ford Bronco Sport Active Grille Shutters on BS AA4E183C-F589-43FF-9090-54D91B456973
Ramseyi
Ramsey
Arlington
I thought I'm the only one notice this. ?
