Thule 53 inch with the 450r legs. They are the same ones we used on the explorer.What crossbars are you guys using with your load warrior by chance?
What brand and size is your rack? Thanks.
Yakima loadwarrior with extension.What brand and size is your rack? Thanks.
And, can it be used with the "Factory" crossbars?What crossbars are you guys using with your load warrior by chance?
Yes, any crossbar should works.And, can it be used with the "Factory" crossbars?
Hi. I was wondering. Will I need crossbars to install a roof rack?![]()
Nice. Here's mine with factory cross rails and Thule canyon xt cargo basket on mine, and I can get in and out of my garage...unloaded of course.
1. Yes. Any basket can fit if your cross bars are long enough. Looks like the large is 9 inches wider than the medium so if you look at my pics with the medium, add 4.5" to each side.Couple of quick questions:
1. Does the large off-grid basket fit the Bronco sport? I can't seem to find the medium in stock.
2. Would the awning fit with the off-grid basket either medium or large?
Yes. The cross bars are what a roof rack sits on/clamps to.Hi. I was wondering. Will I need crossbars to install a roof rack?
Thanks. Do you know a brand crossbar that doesn't overlap the side rail mounts or the Bronco side rails?Yes. The cross bars are what a roof rack sits on/clamps to.
The OEM ones from Ford are probably the only ones that sit flush to the roof rails, unless you were to buy some other ones and chop them yourself.Thanks. Do you know a brand crossbar that doesn't overlap the side rail mounts or the Bronco side rails?
You're awesome. This is really helpful. Thanks!The OEM ones from Ford are probably the only ones that sit flush to the roof rails, unless you were to buy some other ones and chop them yourself.
HungLo's pictures are the OEM crossbars.
Yea, my cross rails are the OEM ones installed by the dealer. I used my Ford Pass points to help me pay for the Thule Cargo Basket at the dealership after delivery. Saved me $210, but I didn't have the dealer install it, they wanted to charge $180 for the install. It's easy enough for self installation. Just take your time to measure where you want it. Here's pic without cargo basket.You're awesome. This is really helpful. Thanks!
